Question about Sander Tools & Hardware - Others
How to change attachments for skill octo sander
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: how do i change the
On the link below is the manual for the sander. It will tell you how to change parts.
https://mdm.boschwebservices.com/MDMCache/English%20[US]//t10/0000000/r00908v-1.pdf
Posted on Apr 23, 2011
Where do l buy spare drive belts for skill 560 watt belt sander
From any hardware store, just bring the old belts with you.
Oct 26, 2016 | Sander Tools & Hardware - Others
My skil octo sander won't rotate with the bottom plate on. With the plate off it rotates just fine, is there a way to fix it? I've tried both tightening and losening the screws.
This happenenrd to my sander two days ago.
I searched online for answers and useful information to solve it but couldn't find any thing.
But, I have good news.
I fiddled with the sander till I just figured out what the issue is.
I've discovered that the ball bearing appears to be busted.
It's bearing #608-2RS
im gonna take it to a shop to have it pulled and I'll replace it and see if it flys.
will update later.
Dec 18, 2015 | Bosch Skil 7207 100W Octo Detail Sander
I have a pressure control skil octo Sander .i think i pressed down to hard now the pressure light stays on and it won't sand but Motor runs good
The transmission between the motor and the sanding belt has been damaged by the excessive pressure you applied. Check it carefully to see if something got bent and operation can be restored. If it is gear driven and you broke off some of the gears then .....................................
Sep 16, 2015 | Skil Tools & Hardware - Others
Where can one purchase sanding belts for a skill 593 sander 2 1/2 X 16?
Search on Amazon for 2-1/2 x 16 sanding belts and you will get a plethora of options
May 07, 2015 | Sander Tools & Hardware - Others
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
I just aquired a used Skil Model 409 orbital sander and am having trouble inserting the paper. Is there a technique peculiar to this machine that?
Sorry, I was missing that part. You got it right, though. three hands is the answer. Orrr, you could go get some nice sticky back papers and cheat. They come in a variety of sizes or can be cut from full sheets. what you have there is a good sander to use while you figure out what kind of sander you want:)
Best regards, Farmerbear
Sep 07, 2010 | Skil Octo Multi Finishing Sander
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
Scuba octopus?
An octo IS a regulator. There are two types or regulators on a typical scuba rig. Your first stage reg that is attached to your tank valve. From this first stage, there are hoses leading to your primary breathing second stage reg and your Octo second stage. The job of the first stage is to bring that possibly 3,000 psi air in the tank, down to a more reasonable pressure of about 150 psi. From there, the air goes to the second stages and can be reduced down further by these second stage, on demand (meaning it delivers air when you inhale and stops when you finnish inhaling), regs. The Octo is a second stage back up for a buddy that is out of air or if your own primary second stage ( the one you normally breathe from) is no longer functioning. Octos are generally ( not always) a cheaper reg, that may not have all the bells and whistles that a primary air source does. It's there for an emergency, so ease of breathing under load and tuning adjustments are minor. It gives you air when you're in a pinch, thats the important thing.
Dec 01, 2008 | Aeris A1 Octo
Tools & Hardware - Others Logo
27 people viewed this question
Top Sander Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
