Question about Refrigerators
How do I turn refrigerator back to what temp - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Posted on Apr 11, 2015
Side by side ge refrig freezing food in refrigerator side temp control working since when turned to zero clicks off what could this be
Probably the temp control is defective and is defaulting to maximum. I would suggest replacing it to be sure.
Feb 01, 2015 | GE Refrigerators
Refrigerator shuts off at correct temp. but does not turn back on
problem thermostat call a technician to properly diagnose and fix
Apr 10, 2017 | Refrigerators
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
Starts beeping when you turn the power on at the wall
sounds like a hi temp alarm going off, maybe a on/off switch at bottom of refrigerator. Try turning it off untill the fridge comes down in temp then turn it back on and see if it goes out.
Feb 21, 2011 | Refrigerators
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not keeping temp.
There is normally a fan in the freezer (usually removing the back panel from inside the fridge will show it [sometimes you need to pull the bottom panel of the freezer off] The panels are normally secured with phillips head screws.). If it doesn't turn, it probably needs replacing. Make sure the coils are not iced over. [unplug while removing panels, then plug back in... the temp will have risen in the freezer so the fan should come on right away].
Make sure that the "vents" in the freezer (bottom of the freezer - in the front back or both) are not covered.
Some fridges have a separate control for fridge temp, make sure that was not moved, or try setting to a colder setting.
Sep 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
HI: We have a 6-7 yr old TRUE single door, stainless steel fridge. We noticed yesterday ..that at "4" on the temp dial, the fridge is freezing milk in glass gallon jars. We backed the temp down to "2" and...
With the refrigerator, the fan inside the conditioned space should always run. This is normal for most all commercial refrigerators. Need to check to see if the unit is shutting off the compressor after the conditioned space reaches a good temp, usually 35 degrees. If not, probably a bad thermostat.
Apr 11, 2017 | True Food VWR Storage Refrigerators with...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
