My machine is 2 months old and makes a horrible thumping noise during the spin cycle. Also the fabric softener compartment won't drain water
  • Jorge Rendon
    Jorge Rendon Apr 20, 2015
    even a bad motor coupler would do it if its direct drive
  • Washing Mach... Master
  • 5,323 Answers
Ugh the thumping noise during spin may mean bad agitator spindle where the splines have been damaged or perhaps a damaged transmission spline, at other times it could be due to bad counter weights . check below
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Posted on Apr 20, 2015
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
My question is this..why doesnt my clothes smell like fabric softner?? They dont smell at all..like i never put anything in there...and the fabric softner compartment never fully drains of its water what...
The fabric softener may be unscented.
The softener compartment is flushed during the wash cycle to clear it completely, therefore some water remains at the end.
Aug 01, 2014 | Washing Machines
After washing it makes loud noise & won't spin or drain
You shoul inspekt water outlet on the bottom of the drum. There is mabye something inthere.
Dec 02, 2017 | Washing Machines
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
