Question about Kitchen Ranges
Broiler and oven will not go on, what could cause this
  • Steve Allison
    Steve Allison Mar 29, 2015
    Hi eric , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    To get a valid answer, you must include make and model info.
No power supply to receptacle
blown fuse or circuit breaker trip or damaged cord wire.
Child lock activated.
Posted on Mar 29, 2015
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
I have a Magic Chef gas oven. The broiler won't turn off. Ihad to shut off the gas and unplug it. Model 3568XVW. Where should I start?
This is usually caused by the main control. The relay for the broiler has likely melted into the on position. Here is a link that should help Replacing oven ERC
Apr 18, 2011 | Magic Chef Ovens
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
GE XL 44 gas oven not working. I replaced the igniter for the oven, but not the one for the broiler. Also replaced the regulator valve. Still doesn't work. I didn't replace the broiler igniter as we...
most newer models of gas oven require electricity in order to work. I would check the outlet where you have your oven plugged in. Plug something else into that outlet to make sure it is live. If it is not, check the electrical panel breaker or fuse.
Oct 29, 2009 | Kitchen Ranges
The broiler and the oven will not heat up/ the oven was on, working fine, starting losing temp. The gas was still on.
Hi Satk78
Since both broiler and bake are affected then the cause is common. The first to consider would be the gas supply - make sure the regulator from the supply is functioning properly
The safety valve is the most likely problem. If a knock on it(safety valve) cause the oven to work better, then, change the safety valve.
Aug 26, 2009 | Tappan Ovens
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
