Question about Drills
Where are the brushes located - Drills
  • Drills Master
  • 1,896 Answers
There are also engines with a closed motor with hammerbrushes , then the motor should be replaced if its worn out.
Posted on Apr 04, 2015
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
Why
Hi! There are a few reasons why your brushes may not be spinning. Try these simple steps below.
1. Your brush roll may be clogged. Unplug the cleaner and remove any debris from brush roll.
2. Make sure the brush roll setting is turned on. The brush roll on/off switch is located on the handle of the hose.
3. Reset the brushes. The brush roll reset button is located on the back of the nozzle on the right side.
Hope this helps! If you still have questions feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jun 19, 2014 | Dirt Devil Vision Cyclonic Canister...
How to locate the washing machine brushes?
Some motors do not have carbon Brushes as its a induction motor as a opposed to a reaction motor which does have, not sure about your model but you could check this first, if it does have a brush kit fitted they should be easy to identify and remove if on the other hand no brushes then you would need to fit a new motor. On the bosch the brushes can be hidden look at the back of the motor ,you will see two wires one for each brush connected. Good luck.
Jun 03, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
Where are the brushes located on an asko washing machine ??? I'm fairly handy, can I replace myself ???
hi, I used to fix asko's when I was as work and found the motor brushes really easy to fix on the older machines. I found it best to drop the motor down and change the brushes at the back of the motor on the bench. hope this helps. remember to change both brushes though.
Mar 25, 2013 | Asko Washing Machines
Need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Indesit W 123 Front Load Washer
I am trying to locate the brushes in my whirlpool awm 5125 washer i have taken the top off but cant locate them
the brushes are on the motor which is located at the rear of the machine sitting just under the wash unit.
You will need a 10mm spanner to remove the bolts holding the motor on. unclip the wiring to the motor and remove.
the carbon brushes are located on the rear of the motor - one on each side of the commutator,
you will need a philips screw driver to remove the brushes
Jan 15, 2009 | Whirlpool AWM5125/1 Front Load Washer
Brushes won't turn remain motionless as if cleaning hard floors even though button depressed could it be a problem with the brushes or button still under guarantee
There is a re-set button located on the brush head on the left side as viewed if you are standing directly behind the vacuum cleaner. It is black in color and is recessed slightly into the cover of the brush cover. It is round and about the size of the head of a country match and sticks up about 1/2 inch. Just press it to reset. Also, don't forget to press the grey on-off brush switch located beside the red on-off which is located near the top of the handle. Hope this information solves your problem. jawebb3@suddenlink.net
Mar 06, 2008 | Dyson DC18 all floors Bagless Upright...
Drills Logo
138 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
