Question about Ovens
Grill won't work - Ovens
    New Friend:
Could be your grill element. Check with an appliance repairer or qualified electrician.
if you think your capable yourself of changing google "the element man"
Posted on Mar 29, 2015
Testimonial: "Thanks, it's a gas grill, think prob is the interlock. Thanks"
I have a Beko SG562. Recently, when I turn the oven on, the gas lights, but it won't stay on
then the thermo couple needs replaced that the pilot contacts call a repairman to replace it .
Feb 09, 2013 | Ovens
My grill uses the same elemant as my grill but grill wont work , but oven will
when you use your grill the oven door must be open if if does not heat then the door switch is faulty
Apr 21, 2012 | Ovens
All oven grill and fan elements dead
The oven will not warm if the clock is not set as the main oven is directly linked to it. You may want to check your wiring to the element you have changed as all elements use the same neutral path, meaning if you missed a wire off (especially if you pulled it out through the oven cavity) or have put them on the wrong tab it won't work. It could also be a duff element (the new one).Let me know if you need any further help.
Dec 07, 2011 | Neff Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
My grill on my cooker keeps going off and on... you cant grill cheese on toast as the grill goes off and the cheese goes cold?
We know that the grill element is working because it does get hot. It sounds like a problem with the grill control.
Feb 11, 2011 | Zanussi Ovens
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
57 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
