Question about Garmin nuvi 200W GPS
Got a used one and do i need a memory card for it to work?
    Scholar:
  • Garmin Expert
  • 186 Answers
That depends. If the device is still registered to someone else, it is worthless for updating. Garmin Express checks the registration when you try to update. The seller would have to deregister the device with Garmin. The device should work as is without an sd card, but you may require one (8gb or less) to install updates as the internal memory is not that big and maps keep getting bigger.
Posted on May 02, 2017
I got it in a will and I would like to use it however it doesnt have memory card does it have to have the memory card in it to work ????
Most digital cameras don't have internal memory reserved for other than system use. When you turn it on, does it says "no memory" or "no memory card" or "no memory card detected" or "please insert memory card"? Anything like that? That would most probably mean that you need to have a memory card for using it. If it doesn't, check the settings, see if there's an option to select what memory to use? If there's no such option, then you definitely need a memory card. I hope that helped a bit!
Sep 01, 2011 | Cameras
I have a canon powershot a540 bought used and i cant not format the memory card
Hi Hello,if your Digital camera and memory card can't format,try to my advice, you get out your memory card to your digital camera,and you can try to reformat your memory using your computer,if the memory card can't format throught using your computer,its mean your memory is need to replace new memory card. hope its work it,thanks
Jul 28, 2011 | Canon PowerShot A540 Digital Camera
The memory card loses data what should i do
download this memory card data recovery program
i have used this once to recover a file off my sd card and it worked... hopefully it works for you too!!!!!
Jan 11, 2011 | Samsung B3410 Cell Phone
When i want my photos go in memory card then i click on shutter button its not go in memory card its tell me internal memory is full why tell me its full information. very thanks for this kindness.please...
This camera needs some internal memory free in order to work at all. It can't use memory in the memory card unless it has some internal memory free. You need to delete some pictures in internal memory.
It should use the memory card memory automatically. If it can't use the card (if card is incompatible) there will be an error message. Some cameras can't use SDHC cards even though they fit in the SD slot. Or the card may need formatting. But first you need to free some memory in the internal memory.
Dec 02, 2010 | Kodak EasyShare C180 Digital Camera
My sagem my521x won't work with 2gb micro sd card. whenever i put it in it says that memory card inserted. but then it doesn't receive music and pix by bluetooth
If the memory card doesn't work with your phone,
you can try using it with another phone that uses the
same type of memory card to confirm if the memory
card needs to be replaced or not.
Feb 09, 2010 | Sagem My501X Cellular Phone
My camera will not read my memory card anymore. It is only using the memory from the camera. How can I get it to read the memory card
Confirm first whether the memory card is still good or bad by using a card reader, put the camera memory card into the card reader then connect it to your system, see whether the system will read your card, if the system doesn't read it, it simply implies that memory card is bad and you need to replace it with a genuine memory card, but if it works it implies that the card slot on the camera is bad. so, your either need to service your camera or you replace the memory card. Thanks
Sep 24, 2009 | HP Photosmart M417 Digital Camera
My sandisk m2 does not get regognised on my mobile phone.
You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
Have a great day!
Aug 16, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
LG Cookie Won't Recognise Memory Card
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD .....you also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Apr 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Nov 03, 2008 | Kodak EasyShare DX7630 Digital Camera
Garmin nuvi 200W GPS Logo
60 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
