Question about Garden
Instructions on replacing a fuel pump on sst15?
  • 1,169 Answers
John Deere Spin Steer 15 with Kohler CV15 engine.
Removal
1. Disconnect the fuel lines from the inlet and outlet fittings of the pump.
2. Remove the hex. flange screws, fuel pump, and gasket.
3. If necessary, remove the fittings from the pump body.
Installation
1. Fittings - Apply a small amount of Permatex® Aviation Perm-A-Gasket (or equivalent) gasoline resistant thread sealant to the threads of the fittings. Turn the fittings into the pump 5 full
turns; continue turning the fittings in the same direction until the desired position is reached.
2. Install new gasket, fuel pump, and hex. flange screws.
NOTE: Make sure the fuel pump lever is positioned to the right of the camshaft (when looking at fuel pump mounting pad). Damage to the fuel pump, and severe engine damage, could result if the lever is positioned to the left of the camshaft.
3. Torque the hex. flange screws as follows:
Into new as-cast hole-9.0 N·m (80 in. lb.).
Into used hole-4.2-5.1 N·m (37-45 in. lb.).
4. Connect the fuel lines to the inlet and outlet fittings.
Instructions on replacing a fuel pump on sst15? - 25615780-webbad2mcwj13tdkavs4rwep-3-0.png
Posted on Mar 31, 2015
Replacing fuel filter
Hello kenny,This article is showing the instructions of replacing fuel pump and fuel filter,you can read it ,How to Replace Fuel Pump and Fuel Filter
Mar 01, 2014 | Cars & Trucks
How do you change fuel pump on 1999 cadillac deville?
How to Replace Fuel Pump and Fuel Filter in Cadillac ,this article is showing the instructions of replacing fuel pump and fuel filter in a Cadillac.Good luck!
Jan 18, 2014 | Cars & Trucks
Do i need to remove the gas tank on buick rendesvouz 2002 to replace the fuel pump?
The hard part is removing the fuel thank. This is really stupid, but unfortunately this is the reality, there should be an exes door to the fuel pump in the trunk, just like in the old Lada.
So when your fuel tank is on the floor, from here is very easy to replace the pump.
With the new pump you will have instructions how to do it.
Have fun.
Mar 17, 2013 | 2002 Buick Rendezvous
I have to replace fuel pump, do you have a procdure to replace fuel pump in 2001 focus wagon, 2.0 split port engine. thanks.
There is a complete guide to remove and install fuel pump.Its a complete procedure.Click this link directly:---- http://technoanswers.blogspot.com/2011/04/how-to-replace-fuel-pump-on-2001ford.html -------------------- Read the instructions mentioned and follow it properly.This will help to replace the fuel pump .Thanks.Helpmech.
Apr 05, 2011 | 2001 Ford Focus
Need to change fuel pump on 1999 xj8 jag
Hi ,
Fuel pumps are no always straight forward, they sometimes retain fuel under pressure and have to be discharged in order to be replaced. If your so sure it's gone (not an easy diagnosis) the replacement instructions will be on the replacement pump instructions or an owners manual. DON'T TAKE CHANCES WITH PRESSURISED FUEL ! Good Luck
Dec 12, 2010 | 1998 Jaguar XJ8L
Fuel pump locatio for a 1965 nustang V8, also the location of the fuel filter if any.
Integral Fuel Pump & Filter (Replaceable Element Type) Prior to 1966, the fuel pump was equipped with an integral fuel filter, featuring a replaceable element. It is recommended that this filter element be replaced every 36 months or 36,000 miles, or in the event that the filter becomes clogged. It is important to use the proper filter element for your fuel pump and to observe the instructions for positioning the element within the fuel pump unit. These instructions will be printed on the replacement element.
Exploded view of the pump mounting
May 12, 2010 | 1965 Ford Mustang
Instructions for replacing fuel pump in a 2001 ford Escort ZX2
Remove the rear seat, remove the 4 screws holding the metal cover, and you'll see the top of the fuel tank. The pump module is held in place by a locking ring that can be removed by use of a brass punch and hammer. If the ring is rusted, it'll get damaged during removal and will need replaced. You can get a new ring from Ford. Once the ring is removed, you can pull the pump module out. Remove the small screws from the top of the module and you can pull the top off of the basket to gain access to the fuel pump. Replace the pump and get new fuel pump strainers.
Feb 09, 2010 | 2001 Ford Escort ZX2
In-the-tank fuel pump r&r
Here are instructions for replacment with a diagram of the fuel pump components my only suggestion would be instead of draining the tank and dropping the fuel tank if you unbolt the box and using a jack and and some wood lift the fuel tank side of the box this will give you access to the tank and fuel pump/ sending unit. It will save you time and the hastle of replacing the tank straps which are prone to snapping at the threads when trying to remove the nuts.If these brake you will have to replace them.
Nov 16, 2008 | 1994 GMC Sierra
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
