Question about Husqvarna Garden
Can someone tell me how to put the belt that pulls the tractor on a husqvarna
  • 74 Answers
SOURCE: husqvarna yth20S42 partial loss of drive power
I would thing its the belt I have same mower u can check rear end by removing a check plug also sure that u can adjust the belt try that 1st
Posted on Apr 18, 2009
  • 81 Answers
SOURCE: HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Posted on Jun 22, 2009
  • 11 Answers
SOURCE: Problem with the Husqvarna Lawn
http://weborder.husqvarna.com/order_static/doc/usa/2009/I09000/I0902011.pdf
Posted on Sep 06, 2010
daneinwv
  • 124 Answers
SOURCE: Yes I need help on
My name is Dane and I am going to help you solve your problem.
Drive belt: 532 13 09-69 Deck Belt: 532 40 51-43
Here's a link to your manuals!!!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=yth20k46&types=O,I
I hope I've helped! Thank you! Dane
Posted on Dec 31, 2010
philwalker78
  • 608 Answers
SOURCE: lawn tractor does not move repl. both belts pull
What brand of mower? You most likely have a broken return spring on the drive system.
Posted on Apr 11, 2011
Have husqvarna model 93605500/a25h54 need diagram for drive belt
If you go to www.Husqvarna.com/us you can put in your model number and get an IPL or owner's manual this will show you how the belt fits on the tractor.
Sep 19, 2014 | Husqvarna Garden
Won't pull it's self. Is there a way to put more tension on belt?
No this is common problem with belt drive tractors and sounds like it is an old belt or the belt is wrong. Replace it with a new belt of the correct length
Sep 28, 2013 | Husqvarna Garden
Husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Tractor will not pull. Replaced drive belt with no success. Ant suggestions?
put some thought into a new hydrostatic transmission. they are expensive, perhaps as much as buying another mower.
Apr 19, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Yes I need help on a Husqvarna model #YTH20K46-960450004 this is a 46" riding tractor. I need a drive belt and deck belt. can someone supply me p/n so I can order plz. thx..Eric
Dec 30, 2010 | Husqvarna Garden
Drive belt
Sounds like u think someone has moved a pulley.
If not, u already know that the back of the v-belt, or flat side runs against flat pulley, most of the time just taking up slack.
The belt probably pulls over the top of the pulley with the back side of the belt rolling on it. Your drive and blade pulleys will keep it in line.
Where's the belt tinsion come from? Spring idler or slide adjustment?
Some times it takes some head scratching but u can figure this out.
ballping
Jul 28, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Clutch adjustment
I had the exact same problem on my Husq 2148 which arose just after a new drive belt was put on. There is a cage around the front, engine, pulley which keeps the belt from flying off I guess. After staring at the belt for a long, 2 beers, time I discovered the repair guy had put the belt inside the cage on one side, where it is supposed to be, but outside the cage on the other side. This caused the problem you described and it ran much better in reverse than forward. If your problem arose after a belt change, I would start looking there, if not then I would check the 2 springs which keep back tension on the pedal. It took me 3 more beers to get the thing put on right.
May 30, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
How to replace belt
Before taking it off notice how the belt loops through all the pullys so you can put it back on. Then I would take it to a store that sells belts and have someone help you find one or just pick one out that is reletivly the same size or partially smaller as belts will get longer with use.
Apr 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Apr 30, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Husqvarna yth20S42 partial loss of drive power can tran oil be checked. The tractor has 170hrs operating time.How can you tell if its the belt or the trans. thanx Rod.
Apr 18, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
