Help, please. I have a 32H6072-DC Last night I fell asleep watching my TV. It is set to turn off after one hour of no use. This morning I awoke to find we had a power cut.. When it came back on it had the message on the screen telling me it had gone into stand by mode and asking me to press the OK key. Now the problem it wont switch to anything. First checked remote control, no problem. Have tried unplugging the set and leaving a few hours. Tried the switch on the TV. quick press or holding for a few seconds. Can you give me any other ideas? If not how do I go about sending it back under guarantee?
  • 274 Answers
SOURCE: Piece of s@#t!
Sounds like you  accidentally "set" the parental lock while you were sleeping.
Try this trick: (may or may not work)
aim the remote at the TV "IR sensor", hold down "display button" on the remote for 10 seconds to erase or clear the password.
"IF" this works go into the menu and "TURN OFF" parental control.
Posted on Oct 20, 2007
satscoop
  • 59 Answers
SOURCE: welcome. powering up" screen freezes
well it sounds like the tivo is trying to re aquire the information needed or it was damaged during the power outage.If you can get into the menu settings make sure that you are getting a satellite signal on both tuners or both cables coming from the satellite.If you have the same tivo thats in the picture then you can go to directv central "the blue button at the top of the remote" then once you get there go to "read new messages and setup,then settings then satellite signal.once you go to the signal testing screen make sure you have a signal on both of the signal meter bars.If you dont one of the cables may have been damged.another way to test to see if the cables are ok is to take another receiver from another room and see if if will work on BOTH the cables that plugged into the tivo.If you discover that one or both cables are not working you can go to a website called satellitescoop.com and there is a section that will explain how to fix the cable/If you are unable to get to the setup screen then something internal may be wrong with the tivo.You will have to call Directv and have the tivo replaced with the new DVR,not tivo anymore.Or you can replace it yourself.Once again the website i mentioned will help ALOT.GOOD LUCK rate me fixya if this helps.OH yeah not dialing out will not cause any problems.Mine is the same way and it will just prompt you to make a phone call.
Posted on Dec 04, 2007
SOURCE: Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
Posted on Jan 21, 2008
yankeegurl
  • 121 Answers
SOURCE: my samsung sp50l7hx dlp tv
usually when that symbol comes up it means your lamp is defective so I would replace the lamp because if you had the set for that long and not replaced the lamp chances are thats your problem and you may be able to get a user manual for your tv by going to this sight
http://www.retrevo.com/
Posted on Apr 26, 2008
SOURCE: TV SET ON STAND BY?
This is to do with the capacitors inside the TV numbers 2662, 2663 and 2664 - If you unscrew the back panel of the tv you will see the capacitors towards the top of the tv, from memory around the middle.
Replace the capacitors (make sure you get the polarity the right way round) and you should find all is ok.
Posted on Jun 19, 2008
LG plasma tv burn in
sorry, thats the problem with plasma's, if it hasn;t cleared up you will have to replace the entire screen.
Oct 25, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
My power button does not stay on (the green lamp)when turned on from the remote or the unit. I checked the fuses on the main circut board and the have contineuity. help model vs-50609 mitsubishi rear...
Could be h.v. splitter.pull the lead coming from the flyback that enters into the h.v.splittter. Put lead in a quart jar and turn the set on and see if you hear a hissing sound, if you don't see a blue arch also. If set stays on then h.v.splitter is bad.
Jul 07, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Dan
Feb 24, 2009 | Sanyo DS31590 31" TV
Sony 46" lcd turns off by itself and will not power up again.
Sony TVs come with a one year warranty on parts and labor. Call Sony at 1-800-222-SONY They will find a local company to service this product.
These TVs have a self-diagnostic screen that a tech can access to help solve the problem. Your problem could be any number of things including the fan(s) stopping, the ballast board failing, Q-box issue or none of the above.
michtech
Feb 19, 2009 | Sony Televison & Video
if your tv unit is still under warranty, first you better bring it back again to the store you just bought it for warranty purposes, your tv has an internal problem, maybe manufacturer defect. Usually the cause of that is a shorted electronics component, say for ex, a mosfet transistor that is located at the power section, or maybe a capacitor that is leaky, and also an open resistor. if you don't know how to troubleshoot this problem, you better have your tv unit repaired by a professional tv technician.
Good luck
Jan 22, 2009 | Sony KDL-46S4100 46 in. LCD TV
7 red blinks
Is the light blinking 7 times on front of TV ? If u take the back cover of the TV off you should see two leds on the bottom right of power supply turn on when u push the power button. When the TV go into error protection on the upper left of power supply you should see. A blinking green light. Please inform me of the error it flashes and ill will be able to help further. ( Serveral possiblilties it could be from audio, bad power,and faulty Y-main.)
Apr 28, 2008 | Philips 42PF9630A 42 in. Plasma Television
My samsung sp50l7hx dlp tv wont turn on,last night i fell asleep while watching and awoke to see tv switch off then back on by itself, colour was dull, this morning i tried turning unit on. it started...
Apr 26, 2008 | Televison & Video
My sansa wont turn on period!!!!
Try charging it, and then holding the power button for like...20 seconds.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
No power
your going to have to check out the main power supply or standby power supply. good Luck
Jul 25, 2006 | Samsung LN-S3251D 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
