Question about CorelDRAW Graphics Suite X4 for PC (CDGSX4ENPC)
May I view corrupt cdr file in win7 ?
There is a corrupted file in a format .cdr CorelDraw version 10. Is there a way to restore it recommendations to restore files on corel.com relate only to the 7 version of the product - not suitable; restore by importing into other programs,
    Master:
  • 416 Answers
Make a back up of your corrupt file first if you can
there are many programs out there that can examine the file and is many cases repair it
the work corrupt is often misleading,
the most common faults causing corruption are
1 the file size is incorrectly recorded
2, the actual location of file is incorred
3, the most common, the file dates are incorrect
4, it has been writen on a bad sector of the hard drive or that sector has since been damaged
it is often possible to run scandisk and fix those files , you may have to select "scan surface and attempt to repair files" but that takes a very long time and with today's large drives may take weeks,
backups are a must
there are programs that analyze the files one at a time or at your choosing that can in many instances, repair these files in a much shorter period of time
Posted on Mar 29, 2015
Can someone help me whith Corel Draw file?
Hello.
Your file may be corrupted or it could be your operating system.
You can use CorelDraw Fix Toolbox
Here the link: https://www.fixtoolbox.com/coreldrawfix.html
It recovery corrupted .cdr files powered by the CorelDraw image editor.
Good luck,
Charley
Sep 01, 2016 | Corel Computers & Internet
How do i fix the problem with corel files damaged by virus?
if your problum is still pleas use this latest matlab 2016 with key tool Matlab r2015a Serial Key Keygen Cracks are Free Download LATEST VERSION
t
if you want use your software so pleas install avast antivirus
avast secureline vpn license key
Mar 16, 2016 | CorelDRAW Graphics Suite X4 for PC...
How do I repair a corrupted CDR file?
try the following:
- rename the file to ".zip "
- open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
- try to repair the file
- then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
These steps work for me.
Or try use CorelDRAW Repair Kit. CorelDRAW file repair software for recovery of the contents of damaged CDR files. Program helps to repair corrupted Corel Draw project files.
Corel Draw repair file
Jul 18, 2015 | CorelDRAW Graphics Suite X4 for PC...
How can i fix corrupted CD? Please help
Hi lajos! try these steps
1. rename the file to ".zip "
2. open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
3. try to repair the file
4. then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
Maybe that utility might be what you're looking for - CorelDraw Fix Toolbox https://www.fixtoolbox.com/cdfreefix.html
Feb 15, 2015 | Computers & Internet
How do i fix CorelDraw?
Hi, these steps work for me.
Maybe that utility might be what you're looking for - CorelDraw Fix Toolbox http://www.coreldraw.fixtoolbox.com/
Or see more http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/707-%E2%80%8Bcoreldraw-corrupt-file-repair
Jan 23, 2015 | Computers & Internet
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
How to cdr repair corrupted image?
If you are using windows 7 or later, you can try opening the folder in windows explorer, right click on the CDR, go to properties and then the previous versions tab. It may have kept an older version.
I can't remember if XP also kept previous versions and it also depends on your configuration, so it is not definite that you will have them.
Another, small, possibility is to look in the same folder and see if you have a file which begins backup_of_... and your filename. But this keeps only one previous copy so if you have saved the file more than once since Wednesday your backup will be too new.
And:
CDR Repair Kit. A must-have CorelDraw CDR repair tool for all categories of users seeking a reliable method of restoring their CorelDraw images after data corruption accidents of various types.
For more information: http://www.cdr.repair/
And here: http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/442-error-reading-problem-in-x3
Nov 06, 2014 | CorelDRAW Graphics Suite X4 for PC...
Error reading coreldraw x5 file
If you are reading off a CD/DVD make sure it is clean and there are not and spots or scratches. If you are reading from a file off a server then you could easily have a corrupted file. Check the file length and make sure it is not zero. Anyone else?
May 24, 2012 | CorelDRAWdent Suite X5
What is a M.cdr file and how can I burn it to dvd to watch on dvd player?and the same for a dmg file?
Detailed information for file extension CDR: File classification: Graphic Mime type: application/cdr, application/coreldraw, application/x-cdr, application/x-coreldraw, image/cdr, image/x-cdr, zz-application/zz-winassoc-cdr Identifying characters: Hex: 52494646, ASCII: RIFF
Program ID: CDraw4 , CorelDRAW.Graphic.8 , CorelDRAW.Graphic.9 , CorelDRAW.Graphic.10 , CorelDRAW.Graphic.11 Associated links: XnView Other applications associated with file type CDR:
  • Elite Plus Commander Saved GameThe Identifying characters used for this association are:Hex: 45 4C 49 54 45 20 43 6F 6D 6D 61 6E 64 65 72 20 46 69 6C 65 1A , ASCII: ELITE.Commander.File.
  • Final Cut Pro CD/DVD Image File by Apple Inc.Final Cut provides Mac users editing tools, sound design, real-time motion graphics and DVD authoring. CDR files are ISO images and, if moved to a PC, can be renamed and burned as ISO files. Associated links: Ken Stone's Final Cut Pro Website
  • GameJack Virtual CD or DVD Image by S.A.D. GmbH.Appears to be an older extension. GameJack seems to use .XMD now.
  • Raw Audio-CD Data
  • Sound File This association is classified as Audio. Associated links: Linux Player
The DMG file type is primarily associated with 'Macintosh OS X' by Apple Inc.. On the Macintosh, these files are treated like a real disk. They can be created with Disk Copy, burnt to CD or mounted as a normal volume. The DMG file also comes in different formats: HFS, HFS+, UFS, ProDOS, Linux, and Fat32 and so may also require special mounting software to account for the format. IsoBuster can interpret these files directly as can other programs such as UltraISO. The program TransMac, by Acute Systems, can both open and create DMG files on a PC.
Oct 22, 2009 | Apple iMac 24" Desktop
CorelDRAW Graphics Suite X4 for PC (CDGSX4ENPC) Logo
59 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
