Plugged into mains, says 'plugged in, charging' 34% activates for about 20 seconds then stops. Never gets above 34%
    Top Expert:
  • Computers & ... Master
  • 4,915 Answers
Will your pc run with it just pluged into the mains with out the battrey in? if it does then it could be your battrey stoping it from running.
Posted on Mar 29, 2015
Testimonial: "Yes it does. Im going to borrow my mates battery to see if it makes a difference."
  • NOEL
    NOEL Mar 29, 2015
    iam sure when you try another battrey all will be ok.good luck and i hope it works for you.
Hi i have a samsung tablet gt-p5210 &it keeps shutting down sometimes i go to play a different game &it just shuts off help!!! Thanks
specify weather it is plugged in or not when this happens and if the battery is above 30%
if plugged in, is the plug getting loose if so replace the wire that charges it and plug will be tight again . clean around plug with folded paper corner to be sure nothing is inside pressed to back of plug slowly shorting power. batteries do wear out in these things so only plug back into charge when it is below 20% and let it charge all the way up. as each partial charge cost you one of the 1000 charges in the battery's life. get Battery Doctor from the play store it will trickle charge at end of cycle and will tell you the battery's health. good app.
Dec 17, 2014 | Samsung Galaxy Tab 3 Tablet 10.1" TFT 1280...
Why phone doesn't power on after charging ?
Frozen.
Does it show as charging when plugged in?
Try the next step when plugged in and/or unplugged.
Try: Hold the Volume Down button and the Power key simultaneously for about 15 seconds. After holding them down for about 20 seconds if the phone didn't power cycle then release the keys and try and turn the phone on like you normally would by briefly pressing the power button.
***If this did not work Try it using the VOLUME UP button with the same process*** this activates a "Power cycle"
Sep 19, 2014 | Sony XPERIA M2 LTE D2306 WHITE 4.8IN...
My phone wont power on EVEN WHEN PLUGGED IN. please send me a list of nearby service centers so they can see im not crazy and exactly what my phone is not doing since maybe part of the problem is i ca
The most common reason a phone won't power on is when the battery is completely dead and a wall charger, not plugged into a computer, is the only way to get it to charge. If plugging it into a wall get's you nothing, then you can try and remove the battery for 10-20 seconds or hold the power button down for 20 seconds to hard reset the device. I would also try purchasing a new charger or take it to your service providers stores and have them try a different charger. Your local providers stores also have repair services if nothing else works.
Nov 23, 2013 | Kyocera Jax Cell Phone
Tomtom one 3rd editon hadn;t been used for some
leave it on charge for 24 hours. if nbo recovery get a new battery
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Tomtom ONE GPS Receiver
NO PICTURE/RED LIGHT KEEPS FLASHING/SOMETIMES PICTURE COMES ON AFTER NOT PLUGGED IN TO POWER
My KV34HS510 Led flashed 4 times then stops for a few seconds and repeats. Is this the D Board MCZ3001D IC problem?
Feb 02, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
Dec 27, 2009 | Braun Flex Integral 6520 Electric Shaver
My phone stopped working. I checked the battery
Check that the base station has power and then place the phone on the cradle on the base station for a minimum of 20 seconds this will reregister the phone security code. If the phone does not start charging or the base seems dead then check that the power pack for the base station in plugged in and turned on.
Apr 13, 2009 | GE 25952EE1 Cordless Phone
Laptop battery
It does charge until the battery reaches full charge, then charger stops and laptop use adapter's power. The whole system is thought to not damage or wear the battery while in charge. Leave battery safely inside your Dell while using it with power adaptor, it should not make any difference in your battery life.
regards
Mar 21, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
