Question about Dualit Food Mixers
Stop start button works three dont - Dualit Food Mixers
What direction should a Hobart H600 mixer rotate?
Check Rotation (Three-Phase Machines Only)
Three-phase machines must be connected so the planetary rotates in the direction of the arrow on the
Drip Cup. To check rotation:
Set the gear shift lever on 1.
Apply power to the mixer, set the Electro-Mechanical Timer on HOLD; or, if equipped with a
Programmable Timer Controller, set it on [ -- : -- ]. With the Bowl Support all the way up,
momentarily run the machine by pushing the START and then STOP buttons.
If rotation is incorrect, DISCONNECT ELECTRICAL POWER SUPPLY and interchange any two
of the incoming power supply leads.
Oct 12, 2017 | Hobart Food Mixers
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Need part for H 600T mixer
I dont think the button is the problem.I suspect the side switch on the contactor is bad.Give me a little more info like when the problem started.
Mar 23, 2009 | Hobart H600 Stand Mixer
Will only stay running if you hold the "on" button down
Look in the bottom back of the pedestal,you will see a cover,remove the cover a contactor start switch and relay will be in there.I suspect the relay is bad,if you dont see a relay its a older unit.What is the ml #? You can find it on the data plate on the b ack.
Feb 13, 2009 | Hobart D340-6009 Mixer
Hobart H600 wont shut off
Sounds to me like the start switch contacts are welded shut.If you have a multimeter set it to ohms,remove 1 wire from the switch,put your meter leads across the switch and if you get a reading that switch is bad.If you dont get a reading i would check the side switch on the contactor.Im a hobartt tech and repair these mixers alot.Let me know.
Feb 11, 2009 | Hobart H600 Stand Mixer
Kitchenaid professional....
It sounds like you need to change the brushes. You can look up your parts manual online here and then buy them online. Should be under $10.
Aug 16, 2008 | KitchenAid KSM50PR Professional Series...
Hobart d-300 mixer
To Whom it May Concer: At the school I work we have a Hobart D-300 Mixer. When we mix bread dough it pulls alot of current and trips the breaker. The max current draw on the name plate is 10.1 amps. I have seen the current go over 30 amps during the mixing process. Under no load the mixer pulls 7.8 amps. I dont have any information about this machine on paper and I can only go so far with troubleshooting.
My questions to you are: Is it normal for the mixer to draw 7.8 amps under no load? And is their a manual online I can look at so I can check the oil levels and make sure I do not have a low oil/needs greasing condition.
Thanks for your help and time,
Kenneth Clayton
Spartanburg Schools Dist#2
Apr 16, 2008 | Hobart D300 Stand Mixer
Hobart Mixer wont start
I apologize but im unable to answer yours or any others at this time.Ive been hijacked by another user on this site that is dropping my rating.I contacted alex@fixya.com (manager) of this site about restoring my account but has yet to do so.If my request fall on deaf ears maybe if you can email him and explain that its hard to get info on any hobart products and im the only one that is a hobart tech answering questions for FREE!!As soon as this matters resolved i will continue to help people as ive been doing for a year on this site.
Apr 01, 2008 | Hobart HL600 Legacy Stand Mixer
Food Mixers Logo
49 people viewed this question
Top Dualit Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Dualit Food Mixer Expert? Answer questions, earn points and help others
