Question about Sherwood Audio Players & Recorders
Sherwood RVD 6095rds Hi. After a short while of about 20 minutes. My speakers cuttout like they are losing connection. Next I hear some loud pops from the speakers. And it resets itself to standby.
  • Matthew Harvey
    Matthew Harvey Mar 31, 2015
    hi there again. thanks for all the input. additional information on the problem. it only seems to happen if the volume is turned up over 25 or more. any more help would be great thank you
  • Glen
    Glen Apr 01, 2015
    Could be a "poor" solder connection causing DC leakage problems. Use a "clenched fist" to lightly vibrate top, bottom, sides of chassis and see if issue appears/disappears.
    Novelist:
    Champion:
  • 225 Answers
Sounds like DC leakage....pre-drive and/or output transistors (or IC) becoming intermittent often pass DC voltages to the speakers. The "pops" you hear are these DC pulses being passed to the speakers and the "cutout" is the protection circuitry doing its job...protecting the speakers. Speakers want AC voltages...plus voltages moving the cone in one direction, and a negative voltage moving it in the opposite direction. DC voltages push the speaker cones in a single direction and hold it there until it fails. The bad news...it's repair shop time.
Posted on Apr 01, 2015
  • Matthew Harvey
    Matthew Harvey Apr 01, 2015
    Thanks for that. I have been researching this extensively. I'm pretty sure it the op amp out put to the front left and right channels. Once I get the amp disconnected from the many wired connections I shall properly bench test my theory. I just hope the parts are still available. Kind regards . matt
  • Matthew Harvey
    I shall give it a try. I will keep you updated on my progress. Thanks
AJIN G
  • 6694 Answers
SOURCE: i need user manual for a sherwood RVD-9090RDS
hi,
I have the user manual for sherwood RVD-9090RDS with me. As it is pdf file i can't sent the same through the Fixya. If you can provide your email id then i will sent the same to you email address.
OK
Posted on Sep 11, 2011
Testimonial: "Hi thank so much for your reply thats grate my email address is terry.ireson@yahoo.co.uk And thank you again Terry "
SOURCE: no power
my be the off/on bottom is not good.no working.
Posted on Aug 05, 2007
SOURCE: Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Posted on Nov 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: SHERWOOD RECEIVER 6108. I
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 23, 2011
technical114
  • 1851 Answers
SOURCE: i would like a manual
Here is an official link for you to download the requested user manual. Note that the user manual for RVD6090 and RVD 6095 are the same, according to the Sherwood USA (take a look at this link, at the Discontinued Models you can locate the same manual for both devices)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 10, 2011
Sherwood RVD-7090RDS when turn on can hear relay click sound but no display
Chances are you have a bad power supply rail that feeds the display, generally its different than any other voltages
Mar 23, 2018 | Sherwood Audio Players & Recorders
My sherwood rx 4109 has no sound what do i do
Pull the sherwood power cord from the wall for 20 minutes. On the back of sherwood, check all cables and make sure they are in the correct places. Check speaker wires and make sure they are connected. 1)After 20 minutes, turn power on to sherwood. 2) select an input (radio, cd, etc.) 3) Push play. 4) Turn volume to desired level.
Feb 07, 2015 | Sherwood Audio Players & Recorders
Manually reset convertible top
basically the unit is recognizing the analog signal but not the digital signal.. may need a converter..
Jan 20, 2014 | Sherwood Audio Players & Recorders
I have a Sherwood RX-4105 Receiver and I am getting no sound through my speakers and the connection with the wires is good so its not that. Any Idea on whats wrong?
when you turn your computer you should hear a sound of a relay initially and after about two seconds another sound, is the closure of the speaker relay models if you do not hear the sounds, the team has some short audio output.
Sep 07, 2013 | Sherwood RX-4105 Receiver
I need user manual for a sherwood RVD-9090RDS
hi,
OK
Sep 11, 2011 | Sherwood RVD-8090R Receiver
I would like a manual for a sherwood rvd 6095 rds please
Thanks and regards
Stelios
May 10, 2011 | Sherwood Audio Players & Recorders
While watching a movie the reciever shuts itself off after several minutes.
Please note exactly after howmany minutes.
If you cannot determine the exaxt time the reciever switchoff.
may be any component on the mother board gets heated up or dry soldered.
try to solder the component.
Jan 10, 2010 | Sherwood RVD-6090R
Sherwood RVD-9090R Left Rear Channel Failure
its due to your player there is nothing wrong with fuse... don't crack the case...try this just connect M1 & M2 to the aux input of your home theater
May 23, 2009 | Sherwood RVD-9090R
RVD 6090R Stopped working after a very brief power outage.
Hi cleitner . It has most likely blown a mains power fuse. You will need to FIRST DISCONNECT FROM THE POWER. Then remove the lid and check internal fuses. Best done with an ohms meter to be sure that you don't miss any. Some fuses can look ok but be faulty. Replace any blown fuses with one of exactly the same type. If you are not sure what type of fuse you need, feel free to get back to me here. Good Luck, thanks for using FixYa
regards
Graeme
Mar 03, 2008 | Sherwood RVD-6090R
No power
Jul 28, 2007 | Sherwood RVD-6095R Receiver
132 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
