Question about Samsung ML-2525W Wireless Mono Laser Printer
My printer has started making a clicking sound and is not printing.
WHY DOES MY HP PSC 1610 MAKES A CLICKING/CLANKING SOUND WHEN STARTING TO PRINT STILL PRINTS
I think your printer required maintenance, because printer time all parts working then your printer print. I gas you some points link printer belt, printer header, printer roller..so any one damage or this types of issue create, so i suggest you contact HP printer technician and check it.
Thanks,
HP Printer Support
May 18, 2014 | HP PSC 1610 All-In-One InkJet Printer
Tip
How to conserve color ink when printing only text documents.
First, make sure you have an updated driver installed in your computer. Visit http://support.epson.com for updated drivers.
To select black ink only mode and conserve color ink when printing only text documents, please do the following:
1. Open the Printers window by following the appropriate steps for your operating system:
In Windows 2000: Click START > SETTINGS > PRINTERS.
In Windows XP: Click START > CONTROL PANEL > PRINTERS AND FAXES or PRINTERS AND OTHER HARDWARE. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear.)
In Windows Vista: Click START > CONTROL PANEL > HARDWARE AND SOUND > PRINTERS.
2. Right-click on your printer name and select PRINTING PREFERENCES.
3. Click the ADVANCED tab.
4. Select the BLACK INK ONLY option.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
When I print, the printer automatically cancels it hence does not print. I am about to throw it out the window. I have a Lexmark 4650
This sounds like a spooler problem on Windows. Make sure the Print Spooler service is enabled. 1. Click on Windows/Start button. 2. Type services.msc in the Start Search box. NOTE: Windows XP users will select Run. 3. Hit Ok. 4. Locate and right-click on Print Spooler, and then click Stop from the drop-down menu. 5. Right-click Print Spooler again, and then click Start from the drop down menu.
Try to print again.
Source: How to Restart or Reset the Print Spooler in Windows
May 10, 2011 | Lexmark X4650 InkJet Printer
Epson sx210 inkjet printer trying to change black ink cartridge but can't find how to get print head to move to correct position to remove cartridge.
If you're using Windows,
XP : Click Start, go to Control Panel > Printers and Faxes Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Vista : Click Start, go to Control Panel > Hardware and Sound > Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
7 : Click Start, go to Control Panel > Hardware and Sound > Devices and Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer will not print from the computer
Good Afternoon, here are a few things to check for.
First, I presume your printer previously printed okay?
If not then I would check the printer cable first.
Unplug then replug the USB cable into the printer. Does the computer make a sound and say found new hardware? If not probably bad cable.
Second, If you get the sound and/or message then cable is fine and we will go on to software.
Go to start menu - control - printers & faxes - double click on your printer icon
Make sure it does not say "Use printer offline" , if it does then click the printer tab & uncheck this option
Next try deleting and reinstalling via manufacturer disc or via website file from manufacturer.
You should try printing a test print before starting and after each step to see if it starts working. (click on printer tab - properties - print test page)
Let me know if this works for you. If not be glad to assist further.
Scott
Feb 19, 2010 | Lexmark X5495 Printer
IT SAYS ITS OFFLINE, I NEED IT ONLINE.
perform the syeps below if you are using XP Operating SystemL
Step 1:
Determine if the printer is paused or offline :
1.Open the printers folder, if necessary.
a.Click the Start icon.
b.Click Control Panel.
c.Click Hardware & Sounds.
NOTE: This step is not required when using Classic view in Windows Vista.
d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2:
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Apr 06, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Doesn't work all of a sudden with vista
First check the printer icon. ( Make sure the printer is turned on during this process)
Go to Start> Control Panel Go to Hardware and sounds> Go to printers.
And check that the printer C3180 has a check mark.
If not right click on the same and left click on Set printer as default.
Next make sure the printer icon says 0Ready.
If not right click on top of the C3180 icon and left click on Clear all documents (untill it says 0ready)
If it still does not say 0Ready.
Then Go to Start> Then Run(if not where you see start search Type there as Run and hit enter> in the run Box type services.msc and click Ok
Now in the services window> Scroll down an locate for Print Spooler and double click on the same>
Now under Services status If Start is highlighted Cliick on start ( now a small window aill poppup and close)
If Stop is highlighted then click on stop ( A small window will popup and close, Now you will see start highlighted> Click on start and then either click on apply or ok close all the windows and restart your computer.
Now First
Go to Start> Control Panel Go to Hardware and sounds> Go to printers.And check that the printer C3180 has a check mark and if it says 0Ready.
If yes Right click on the same icon and left click on Properties.
Now in this window towards the bottom right you will see a tab which says print test page>Click on it to see if it prints a test page.
If yes then Try to print a document.
If non of this works>
Go to Start> Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware)
And deleted any or all the icon which says C3180
If it is not deleting then right click on the same icon and lecft click on cancel all documents> Then unplug the USB cable which is connected to the printer end and leave it unplugged for atleast 1Mins before reconnecting> (In the meantime reboot your computer)
After rebooting the computer connect the USB cord to the Computer it should install the printer diriver on its own> (if it prompts the CD then insert the Cd if you have it handy) it may take some time to install the prnter driver
Then
then C3180 See.if it says 0Ready>Right click on the same icon and left click on Properties>
Now in this window towards the bottom right you will see a tab which says print test page>Click on it to see if it prints a test page then try printing any document or Email.
Let me know if any problem
Good Luck
Sep 30, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer won't wor with vista
sorry we got cut off glad you sent the email
first i need you to check and see if your printer is online
click on your start button then click control panel then were it says hardware and sound below it click printers then right click on your printer make sure its not the fax one make sure it says use printer offline if it does then its fine if it says use printer online then click it
ok if that is good then click propeties then click the advance tab up top make sure these areas are checked
always available
priority set to one
spool print documents etc etc
start printing immediately
print spooled documents first
enable advance printing features
ok now click the security tab and click on everyone
make sure the print allow box is checked
let me know if this fixes it if not we''ll go further into it
Feb 08, 2008 | Computers & Internet
My printer says it is offline and now it wont print
perform the steps below if the Operating System is XP
Step 1:
d.Click Printers.
3.Click Printer.
Step 2:
Nov 28, 2007 | HP DeskJet 340 InkJet Printer
Samsung ML-2525W Wireless Mono Laser Printer Logo
64 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
