Why does my proline laptop makes a beep sound when I start it up and then shut down
    Top Expert:
  • Computers & ... Master
  • 4,837 Answers
As above its ment to.
Posted on Mar 29, 2015
    Top Expert:
  • 10,875 Answers
Its supposed to
3 Suggested Answers
  • 107 Answers
SOURCE: iam using lennovo y410 series.my lapton suddenly
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Posted on Feb 22, 2009
  • 1288 Answers
SOURCE: NEC Versa p8210 Laptop Power Shut down fault
The beeping ounds like overheating, assume you cleaned out the laptop cpu fan and heat sink when you had it apart?
The shorting issue that you refer to, indicates that there is an internal fault in the circuit that carries the DC power to the board. I would dismantle the laptop and try to power it on on an insulated bench, to see if you can spot any arcing as the Adaptor is plugged in. Check the board and look for the inline ceramic fuse, use a multimeter set to the OHMS scale and test the integrity of the fuse to see if it is carrying a current (battery out and unplugged from mains obviously). Then look to see if there are any blown or burned capacitors and resistors on the board or any burned circuit traces.
Also try a different adaptor and check the output voltage of the old one
Posted on Jun 21, 2012
I have a Proline W763S laptop and it won't start
Whats plugged into laptop ? Try unplugging any USB and any external VGA cables. Try holding down power button for 30 seconds and then try again. Also Try power button being held down for 30 seconds to shut down laptop and then remove power cord and battery and then reinsert them into laptop.
Sep 08, 2014 | Computers & Internet
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer Computers & Internet
Beeping noise start
It sounds like a graphics problem but try taking your ram out and re seating it and the same with your hard drive this may cause beeps too
Jan 22, 2014 | Acer Aspire 5733z-4851
Will you please help? I have no sound on my head set when I plug it in my Proline laptop P1642. I am useing Windous XP pro
1. Make sure you are having correct drivers installed for your sound card
2. If you are using realtek sound controller, change settings from there...
and not to mention make sure your headset is working.... :)
Apr 17, 2013 | Computers & Internet
My proline w763s works fine if i press down the keyboard in the middle not anywhere else but if i dont press anywhere it give me continouos long beeps and restarts after a few minutes.the beeps starts at...
has it been dropped,sounds like a loose connection as the keyboard plug is around the centre under the keyboard,if you can get the keyboard of id check the plug,the keyboardsare usually quite easy to take out
May 12, 2011 | Computers & Internet
Laptop shuts down automatically and emits a beeping sound
Yes this is for the memory problem...Try to change the RAM...
Oct 20, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
Compac laptop nc6000 tries to start up then shuts
For all troubleshooting, make sure the laptop is connected to the DC power cable rather than running off the battery.
are you getting any beeps? if not, it's probably bad system board or cpu. if you are getting beeps, then that beep code will usually give a clue as to the failing hardware.
Oct 03, 2009 | Computers & Internet
A beep sound is coming from my laptop during booting
hi,
This is the mike sensitivity issue.
If you are using windows vista then please go in sound properties and then go to recording tab there in levels u will find microphone boost please make it zero.
if u are using xp then please make microphone mute.
May 29, 2009 | IBM ThinkPad T30 2366 Notebook
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
My laptop keeps making beeping sounds when i type.HELP!!!
Do a system restore to a point previous to the power failure shut down. It sounds like the abrupt shut down glitched the system.
Jul 13, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
