Question about PC Laptops
Keyboard won't respond
My keyboard won't respond when turning on the computer where i type in my name an dpasswork it works at this point but once i try to typre like in Excel or in Email or word it won't work
I've rebooted, uninstallede the keyboard ran a scan and can't figure it out even went to a restore point and didn't dix problem HELP HELP
Geniffer Slack
  • 71 Answers
Re: keyboard won't respond
It is odd that it will type before you log in, but not after.
If you have access to a USB desktop keyboard try using that to see if it works after windows has been logged in.
I'd also check the Device Manager. You can get their by clicking on the start button, then click run. After the box pops up type "devmgmt.msc" into it. This will pop up a box that shows you all the devices in your computer. When this is open find the keyboard section and click on the ' + ' . After the keyboard section is expanded look to see if anything under their has a red ' x ' or a yellow exclamation point through it. If it has one of these symbols, double click on it and try to enable the device. Let me know if this doesn't do anything, there may be 1 or 2 more things to try.
Posted on Nov 14, 2007
0 characters
3 Points
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP PC Laptops
    Why is keyboard not responding?
    This answer relates to keyboard hardware issue only.
    On powering on PC look for keyboard lights flashing.
    If no flash. Power down. Remove/replace kbd plug.
    If still no flash of lights then please read on.
    If kbd is old ps/2 type. Which is small round, sometimes purple, plug.
    Ensure its not in not in the similar mouse socket.
    Check for bent pin in plug.
    ps/2 sockets can fail (as can keyboards)
    If no joy and no other ps/2 keyboard works, consider replacing with usb type.
    If kbd is usb type, do power off/on look for lights flashing.
    If no flash of lights, try in different usb port.
    Try replacing keyboard.
    Hope this helps.
    Jul 24, 2015 | Dell Inspiron PC Laptops
    I have an HP G42 the laptop won't boot or start
    HP laptops are well known for motherboard issues, and will usually involve a replacement board, at this point have it checked before a decision is made.
    Sep 26, 2012 | PC Laptops
    You can do a power drain how?
    Just follow these steps:
    1. Shutdown the laptop/netbook.
    2. Unplug the AC power cord (charger) from the laptop and remove the battery. (You can refer to you manual on how to remove the battery)
    3. Now with the battery and charger unplugged, just press and hold the power button of your computer for 20-30 seconds.
    4. Now release the power button, plug in the battery and turn on the computer. It should perform much better now.
    5. Then you can check if your keyboard is working. :)
    Jul 06, 2011 | Acer Aspire One Netbook
    The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
    First of all Turn of your laptop.
    Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
    You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
    If it doesn't boot.
    Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
    Once you get the reply here, we will see what we can do.
    Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
    Sony vaio laptop is turning on but the keybord+mouse not working
    If your Keyboard and mouse are PS2 type, turn off your system, unplug them and try a USB type mouse and keyboard instead. If you are already using USB type mouse and keyboard, then try plugging them into different USB ports. Bootup in Safe Mode if possible. If you do not have keyboard functionality during the initial boot process, you may have sustained damage to the motherboard. The fact you mentioned a noise (speaker type?) and then lost component function, would indicate a possible hardware failure
    Apr 14, 2010 | PC Laptops
    Windows xp won't let my toshiba laptop type anything. I just ran a scan on my computer with Ad Aware and it told me I had Malware on my computer and removed it. When it finished removing it, it said to...
    Search for and download Windows Password Unlocker . Burn it to a CD or usb then boot to that CD on her computer. From there on it should be "kinda" self explainable. If not there are a bunch of tutorials on google search on how use Windows Password Unlocker.
    Sep 15, 2009 | Toshiba Satellite A105 Notebook
    Keyboard and mouse unresponsive under Windows. OK with LinSpire
    Have u tried uninstalling the keyboard and mouse under the device manager .. then reboot your computer
    Mar 30, 2009 | Acer Aspire 3000 Notebook
    PC Laptops Logo
    1,371 people viewed this question
    Top PC Laptops Experts
    Brian Sullivan
    Brian Sullivan
    Are you a PC Laptop Expert? Answer questions, earn points and help others
