Question about Garden
No fuel from tank - Garden
    Sergeant:
  • Garden Expert
  • 187 Answers
For an answer specific to your machine we need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one.A short description of the events preceding the beginning of the problem is also helpful.
Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling
  2. Is there a cut off valve at the gas tank?If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look at least 1/2 full of fuel.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
    Do yourself a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank.Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started.I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger.Once you have a good fuel flow out the line to the filter, put on a FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  4. Check the fuel pump.The fuel pump system on the twin Koehler and the Twin Briggs (and others) are almost identical. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. . https://www.youtube.com/watch?v=HAUZUPoopSI
  5. Note: My engine was starting hard and dying in the field this year (March 2015).While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump.It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  6. Many systems have a fuel shut off solenoid. This is a small cylinder on the bottom of the carburetor. It has two wires running to it. It should make an audible click when you turn the key on. If it does not click you will have to replace it or track down an electrical problem.
  7. If this has not solved the problem you may have to remove and disassemble, clean, or rebuild the carburetor at this point.You may have water, dried fuel (varnish) or trash in the carburetor bowl.Before removing and disassembling the carburetor try draining the bowl.Or, take the bowl off, careful not to drop the small parts inside.Clean the bowl and replace.I often remove the bowl on small engines and save the hassle of a complete carb removal.
NOTE: Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info and I will walk you through the next step.Tracking down a spark problem; yes, your problem could involve the coil. (Not as likely as fuel)
Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
Posted on Mar 29, 2015
Remove fuel tank on 95 Ford aerostar. It has a vapor leak we must repair a leak in vapor recovery system
Removal and Installation
  1. NOTE: Make sure fuel tank (9002) is properly supported during removal and installation procedures.
    Drain fuel from fuel tank .
  1. Loosen fuel tank filler pipe clamp.
  1. Remove fuel tank heat shield (9A032) from vehicle.
  1. Support fuel tank .
  1. Remove bolt from rear fuel tank support strap (9092) and remove rear fuel tank support strap .
  1. Remove bolt from front fuel tank support strap and remove front fuel tank support strap .
  1. Partially lower fuel tank to gain access and remove feed and return lines from sender ports. To disconnect push connect fittings, refer to Push Connect Fittings in this section.
  1. Remove electrical connector from sender unit.
  1. Remove fuel vapor hose from evaporative emission valve (9B593) .
  1. Lower fuel tank from vehicle.
Apr 04, 2017 | 1995 Ford Aerostar
How do I remove the gas tank out of a 2006 Ford 500 no one knows
SECTION 310-01: Fuel Tank and Lines 2006 Freestyle/Five Hundred/Montego Workshop Manual REMOVAL AND INSTALLATION
All vehicles
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
  1. Release the fuel system pressure. For additional information, refer to Section 310-00 .
  1. Drain the fuel tank. For additional information, refer to Section 310-00 .
All wheel drive vehicles
  1. Remove the rear driveshaft. For additional information, refer to Section 205-00 .
All vehicles
  1. Remove the muffler. For additional information, refer to Section 309-00 .
  1. Disconnect the fuel vapor control tube assembly valve-to-fuel vapor tube quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel supply tube-to-fuel filter quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel vapor tube-to-fuel vapor control tube assembly valve quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel tank wiring harness electrical connector at the rear of the fuel tank.
  1. Release the clamp and remove the fuel tank filler hose from the fuel tank.
  1. Place a suitable lifting device under the fuel tank.
  1. Remove the 2 front fuel tank strap bolts.
    • To install, tighten to 35 Nm (26 lb-ft).
  1. NOTE: Do not bend the fuel tank straps.
    Loosen the 2 rear fuel tank strap bolts and position the 2 fuel tank straps aside.
  1. Lower the fuel tank enough to move forward, clear of the fuel straps then complete the lowering procedure.
  1. To install, reverse the removal procedure.
Procedure revision date: 08/19/2009
May 03, 2016 | Ford Cars & Trucks
How do I remove a fuel tank from a 2004 Buick Rendezvous
First of all, there is a recall for gas tank replacement for your vehicle. The dealer will replace it free. The link will get you to the document in PDF form
Redirect Notice
It looks like there is a bracket on one end of the tank hidden by a heat shield
FUEL SUPPLY SYSTEM Fits Buick Rendezvous
Feb 08, 2015 | 2004 Buick Rendezvous
What is the best way to change the fuel pump?
Hi, welcome to FixYa.com my name is Shawn and I will be answering your question.
  1. Relieve the fuel system pressure. Refer to the procedure in this section.
  1. Disconnect the battery ground cable (14301) .
  1. Drain the fuel from the fuel tank (9002) . Refer to the procedure in this section.
    Fuel Tank and Related Components
  1. Raise and support the vehicle.
  1. Remove the two pins from the fuel tank front protector.
  1. Remove the three fuel tank front protector bolts and remove the fuel tank front protector.
  1. Disconnect the evaporative emission hose (9E325) from the evaporative emission valve (9B593) .
  1. NOTE: Label the fuel return line and fuel supply line to ease installation.
    Loosen the fuel return hose clamp and slide it away from the fuel return hose connection.
  1. NOTE: Use a rag to prevent fuel from spilling while disconnecting the fuel lines.
    Disconnect the fuel return hose at the fuel tank .
  1. Loosen the fuel supply hose clamp and slide it away from the fuel supply hose connection.
  1. Disconnect the fuel supply hose at the fuel tank .
  1. Disconnect the fuel pump and bracket electrical connector.
  1. Loosen the hose clamp from the fuel tank to filler pipe hose (9047) and slide the hose clamp toward the fuel tank .
  1. Separate the fuel tank to filler pipe hose from the fuel tank filler pipe (9034) .
  1. Place a jack under the fuel tank to support it when the fuel tank support straps are removed.
  1. Remove the two fuel tank support strap bolts and allow the fuel tank support straps to hang down.
  1. Remove the spring clips from the fuel tank support strap hinges.
  1. Remove the fuel tank support strap hinges and remove the fuel tank support straps.
  1. NOTE: An assistant may be necessary to remove the fuel tank .
    Lower the fuel tank from the vehicle.
I hope my assistance helped you and resolved your concern, if you need further assistance please ask.
Aug 08, 2011 | 1995 Mercury Villager
Removal of gas tank
Fuel Tank Assembly Removal & Installation Single Tank To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section
  2. Relieve fuel system pressure (See: Fuel System Relieving)
  3. Disconnect the negative battery cable
  4. Raise and support the vehicle
  5. Drain the fuel tank in an approved container
  6. Remove or disconnect the following:
    • evaporative emission (EVAP) canister Disconnect fuel lines for single tank gm_trk_sub15_fuel_line_rem_singl_tnk.gif
    • Chassis fuel lines (B) at the fuel tank (A)
      1. Cap the fuel and EVAP lines to prevent possible fuel system contamination
    • EVAP vent line at the fuel tank clip (E) Disconnect vent hose and filler hose gm_trk_sub15_vent_filler_hoses.gif
    • Vent hose and filler hose clamp (D, B)
    • Vent hose and filler hose from the line
  7. With the aid of an assistant or a suitable jack support the fuel tank
  8. Remove or disconnect the following:
    • Fuel tank strap attaching bolts
    • Fuel tank straps
  9. Carefully lower the rear of the fuel tank slightly
  10. Remove or disconnect the following:
    • Fuel sender and the fuel pressure sensor electrical connectors
    • Fuel tank
  11. Place the fuel tank in a suitable work area Fuel lines at the tank gm_trk_sub15_fuel_lines_at_tank.gif
  12. Remove or disconnect the following:
    • Fuel feed and return lines (C) from the fuel sender and the retaining clips
    • Fuel pump assembly from the fuel tank
    • EVAP line from the fuel tank roll over valves (B, D) and the retaining clips (A)
    • Fuel fill hose and the vent hose from the fuel tank
    • Fuel tank
To Install:
  1. Install or connect the following:
    • EVAP line to the fuel tank roll over valves and the retaining clips
    • Fuel pump assembly to the fuel tank
    • Fuel feed and return lines to the fuel sender and the retaining clips
    • Fuel fill hose and the vent hose to the fuel tank; torque hose clamps,
      1. Torque to: 22 lb-in. (2.5 Nm)
  2. With the aid of an assistant or a suitable jack support and partially raise the fuel tank front end first
  3. Install or connect the following:
    • Fuel sender cover
  4. Fully raise the fuel tank
  5. Install or connect the following:
    • Fuel tank straps
    • Install the fuel tank strap attaching bolts;
      1. Torque to 30 lb-ft. (40 Nm)
    • Fuel fill hose and the vent hose to the lines;
      1. Torque hose clamp to 22 lb-in. (2.5 Nm)
  6. Torque the vent hose clamp,
    • Torque to: 22 lb-in. (2.5 Nm)
  7. Connect the EVAP vent line to the fuel tank clip
  8. Remove the caps from the fuel and EVAP lines
  9. Install or connect the following:
    • chassis fuel lines at the fuel tank
    • EVAP canister
  10. Lower the vehicle to the ground
  11. Fill the fuel tank with clean fuel
  12. Install the fuel filler cap
  13. Connect the negative battery cable
  14. Use the following procedure to inspect for leaks:
    • Turn the ignition on for two seconds
    • Turn the ignition off for 10 seconds
    • Inspect for fuel leaks
  15. Install the engine sight shield
  16. Road test the vehicle to check performance
Feb 12, 2011 | 2000 GMC Sierra
Where is the fuel pump on a 1997 Mercury Cougar XR7 and how di get to it?
It's inside the fuel tank. Access is on top. Remove tank. 2 straps hold it in place.
Removal
  1. Relieve fuel system pressure as described under Fuel System Pressure Relief.
  1. Drain fuel from the fuel tank as described.
  1. Raise vehicle on hoist.
  1. Remove the exhaust system as required. Refer to Section 09-00.
  1. NOTE: The connections for the rear fuel supply return and vapor tube (9S278) to the fuel pump module are on top of the fuel tank and are inaccessible. They must be disconnected with the fuel tank partially lowered from the vehicle.
    Disconnect fuel tank to filler pipe hose (9047) and vent hoses connecting the fuel tank filler pipe (9034) to fuel tank. Disconnect one end of the vapor crossover hose at the rear over the driveshaft (4602).
  1. Place a safety support under the fuel tank. Remove the bolts from the fuel tank support straps (9092). Take care not to deform the fuel tank or fuel tank support straps. Fuel tank capacity and/or fuel pick-up may be adversely affected.
  1. Partially remove the fuel tank and disconnect the rear fuel supply return and vapor tubes at push connect fittings using Fuel Line Disconnect Tool Set T90T-9550-S. Disconnect electrical connector from the fuel pump module.
  1. Remove fuel tank from the vehicle.
Nov 12, 2010 | 1997 Mercury Cougar XR7
How to Change a Fuel Pump on an 2005 Envoy XLT? Must drop the tank? Does it have access under the rear seat?
Usually there is no access under the rear seat for safety reasons.prev.gif next.gif Fuel Tank Removal & Installation 2002-2004 To Remove:
  1. Relieve the pressure in the fuel system.
  2. Lift the vehicle.
  3. Remove the frame brace from the frame.
  4. Remove the fuel tank shield from the fuel tank.
  5. Drain the fuel from the tank into an approved container.
  6. Loosen the fuel hose clamp and disconnect the hose from the fuel tank.
  7. Disconnect the evaporative emission (EVAP) vent valve and fuel tank pressure sensor connectors. Evaporative emission cansister pipes removal and installation gm-05-00-1546.gif
  8. Disconnect the evaporative emission (EVAP) vapor and vent valve pipes from the evaporative emission (EVAP) canister.
  9. Disconnect the fuel return and feed pipes from the fuel tank.
  10. To avoid system contamination, cap the evaporative emission (EVAP) and fuel pipes.
  11. Use a jack to support the fuel tank. Fuel tank removal and installation gm-05-00-1547.gif
  12. Detach the fuel tank straps from the frame.
  13. Lower the fuel tank.
  14. Disconnect the fuel sender connector.
  15. Remove the fuel tank from the vehicle.
To Install:
  1. Place the fuel tank under the vehicle.
  2. Connect the fuel sender connector.
  3. Attach the fuel tank straps to the frame. Torque the bolts to 24 ft-lb (32 Nm).
  4. Remove the caps from the evaporative emission (EVAP) and fuel pipes.
  5. Connect the evaporative emission (EVAP) vapor and vent valve pipes to the evaporative emission (EVAP) canister.
  6. Connect the evaporative emission (EVAP) vent valve and fuel tank pressure sensor connectors.
  7. Connect the fuel hose to the fuel tank. Torque the clamp to 22 in-lb (2.5 Nm).
  8. Connect the fuel return and feed pipes to the fuel tank.
  9. Lower the vehicle.
  10. Refill the fuel tank.
  11. Turn on the ignition for 2 seconds, with the engine off, and then turn off the ignition. After 10 seconds, turn the ignition back on with the engine off.
  12. Lift the vehicle.
  13. Check for leaks in the fuel lines.
  14. Install the fuel tank shield onto the fuel tank.
  15. Install the frame brace onto the frame.
  16. Lower the vehicle.
2005-2007 To Remove:
  5. Drain the fuel from the tank into an approved container. Evaporative emission cansister pipes removal and installation gm-05-00-1544.gif
  6. Disconnect the evaporative emission (EVAP) canister fresh air, solenoid, and purge pipes from the evaporative emission (EVAP) canister.
  7. Disconnect the fuel filler pipe recirculation hose from the fuel tank.
  8. Loosen the fuel fill pipe clamp and disconnect the pipe from the fuel tank.
  9. Disconnect the fuel feed and evaporative emission (EVAP) pipes from the fuel tank.
  10. To avoid system contamination, cap the pipes.
  11. Use a jack to support the fuel tank. Fuel tank removal and installation gm-05-00-1545.gif
  14. Disconnect the evaporative emission (EVAP) vent valve, fuel tank pressure sensor, and fuel sender connectors.
To Install:
  2. Connect the evaporative emission (EVAP) vent valve, fuel tank pressure sensor, and fuel sender connectors.
  3. Lift the fuel tank.
  4. Attach the fuel tank straps to the frame. Torque the screws to 24 ft-lb (32 Nm).
  5. Remove the caps from the pipes.
  6. Connect the fuel feed and evaporative emission (EVAP) pipes to the fuel tank.
  7. Connect the fuel fill pipe to the fuel tank. Torque the clamp to 22 in-lb (2.5 Nm).
  8. Connect the fuel filler pipe recirculation hose to the fuel tank.
  9. Connect the evaporative emission (EVAP) canister fresh air, solenoid, and purge pipes to the evaporative emission (EVAP) canister.
  10. Lower the vehicle.
  11. Refill the fuel tank.
  12. Turn on the ignition for 2 seconds, with the engine off, and then turn off the ignition. After 10 seconds, turn the ignition back on with the engine off.
  13. Lift the vehicle.
  14. Check for leaks in the fuel lines.
  15. Install the fuel tank shield onto the fuel tank.
  16. Install the frame brace onto the frame.
  17. Lower the vehicle.
Jul 11, 2010 | 2005 GMC Envoy Xl
Where is the fuel pump located and what does it look like (Mazda 94 Proceed)
I believe this is same truck as Ranger
Pump is in tank
Removal
NOTE: On some vehicles, fuel gauge sending unit is not available separately. On those vehicles, to replace sending unit, replace entire fuel pump .
  1. Remove fuel tank as described in this section.
NOTE: Make sure fuel tank is properly supported during removal and installation procedures.
  1. Drain fuel from fuel tank .
  1. Loosen fill pipe clamp.
  1. Remove bolts securing shield and bracket assembly to frame (5005) and remove assembly from vehicle.
  1. Remove fuel tank filler pipe from vehicle.
  1. Remove bolts and nuts from rear fuel tank support strap and remove rear fuel tank support strap .
  1. Remove bolt and nut from front fuel tank support strap and remove front fuel tank support strap .
  1. Lower fuel tank .
  1. Remove fuel feed hose at sender push connector.
  1. Remove fuel return hose at sender unit push connector.
  1. Disconnect sender and fuel pump electrical connector.
  1. Remove fuel vapor hose from fuel vapor valve .
  1. Remove fuel tank to bench. Remove any dirt that has accumulated around the fuel pump attaching flange so that it will not enter the fuel tank during fuel pump removal.
  1. Turn the fuel tank sending unit locking retainer ring (9A307) counterclockwise with the Fuel Tank Lock Ring Wrench Tool T90T-9275-A or T86T-9275-A and remove fuel tank sending unit locking retainer ring .
  1. Remove the fuel pump and sender assembly.
  1. Remove fuel pump mounting gasket (9417) and discard.
  1. If necessary, disconnect spade connector and remove two screws and fuel gauge sending unit.
Jun 25, 2009 | 1994 Mazda 2WD B Series Pickup
How do you replace the gas tank on a 99 Ford Econoline Van?
this is for gas tank behind axle, not in front of axle.
SECTION 310-01A: Fuel Tank and Lines—Gasoline and Diesel 1999 Econoline Workshop Manual
REMOVAL AND INSTALLATION Fuel Tank — Aft-of-Axle
Special Tool(s) sxm~us~en~file=st1399a.gif~gen~ref.gif Fuel Line Disconnect Tool
310-5039 (T90T-9550-5) sxm~us~en~file=st1130a.gif~gen~ref.gif High-Lift Transmission Jack
014-00942 or equivalent
Removal
sxm~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
sxm~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Fuel in the fuel system remains under high pressure even when the engine is not running. Before repairing or disconnecting any of the fuel lines or fuel system components, the fuel system pressure must be relieved to prevent accidental spraying of fuel, causing personal injury or a fire hazard.
NOTE: The 55 gallon aft-of-axle fuel tank (9002) is shown; the 35 gallon aft-of-axle fuel tank is similar.
  1. Disconnect the battery ground cable.
  1. Relieve the fuel pressure; refer to Section 310-00A .
  1. Drain the fuel from the fuel tank; refer to Section 310-00A .
  1. Raise and support the vehicle; refer to Section 100-02 .
  1. NOTE: In this illustration, the vehicle body is shown removed for clarity.
    Disconnect the fuel tank filler pipe (9034) and the filler vent tube from the fuel tank.
  1. Position the jack under the fuel tank.
  1. Remove the 3 bolts.
  1. Remove the 3 nuts.
  1. Remove the fuel tank support straps (9092).
  1. Partially lower the fuel tank.
  1. Disconnect the fuel lines from the fuel pump (9350); refer to Section 310-00A .
  1. Disconnect the fuel pump and fuel tank sending unit electrical connector.
  1. On gasoline fuel tanks, disconnect the hose(s) from the evaporative emission valve (9B593).
  1. On gasoline fuel tanks only, disconnect the fuel tank pressure sensor electrical connector.
  1. Lower the fuel tank.
  1. If the fuel tank is being replaced, transfer the fuel pump, fuel tank sending unit, the evaporative emission valves and the fuel tank pressure sensor (gasoline fuel tanks) or the plug (diesel fuel tanks) to the new fuel tank.
Jun 17, 2009 | Ford Econoline Cars & Trucks
Starving for gas
check fuel filter first. rate as fixed if this helps.
Steel Midship, Aerostar
Apr 28, 2009 | 1995 Ford Aerostar
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
