Question about Exercise & Fitness
My pro form xp 680 crosstrainer runs fine but after a minute or so it will just stop moving i have tightened the belt and lubed it would it be electronics?
    Top Expert:
  • 10,875 Answers
It is getting hot,too tight?
Posted on Mar 29, 2015
SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
Posted on Jan 26, 2010
bwinton
  • 83 Answers
SOURCE: how to tighten belt...Vitamaster by Roadmaster
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
bwinton
  • 83 Answers
SOURCE: treadmill seems to slip while running,
maxtreadmill
  • 832 Answers
SOURCE: Pro-Form Crosstrainer XP 580 Board Failure?
Their is a sensor within the incline motor casing that may not be functioning thus causing the motor to repeat the cycle. You will most likely need to replace the incline motor.
Posted on Jul 19, 2010
Testimonial: "Max was spot on - I ordered a replacement incline motor and replaced it this morning. Our treadmill is working great again. Thanks, Max!"
maxtreadmill
  • 832 Answers
SOURCE: when walking on my pro form xp weight loss 620,
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on Jul 20, 2010
Sudden Stoppage of my Treadmill
see the video and fix it. Lube too the rollers bearing front and rear+test the drive belt motor and replace if necessary. tight a little.
God bless you
Jun 15, 2013 | Proform Exercise & Fitness
Is there a weight limit on the Pro-Form 760 EKG treadmill? While I am walking the belt skips and I feel like I am going to fall.
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
Aug 24, 2011 | Proform 760 CrossTrainer Treadmill
My treadmill runs for 15 minutes than stops for a minute than start up for 10 minutes than stops, than start up
It is designed to be able to be restarted after about 5 minutes. When it stops, wait 5 to 10 minutes, reset the circuit breaker. Of course you still have the same problem.
The motor contoller board is most likely overheating do to friction, so you're going to need to lubricate the walking belt(this should actually be done every 6 months) you can order a kit on ebay for about 15-20 bucks, it's called " lube n walk ", and no, I don't sell it, but I use it on the treadmills I service.
I recomend you loosen the belt one full turn on each side before you lube the belt, apply the lube and run the treaadmill for one mile without anyone on it and then let it rest for a while.
After that give it a try. if the belt slips, then tighten it back up one turn, but don't over tighten it.
I also recomend using a single outlet surge supressor.
That should solve your problem.
Jan 11, 2011 | RTO Image 15.0R Treadmill Walking Belt
I have a pro-form 680 LT less than a year old. The belt seems loose, it catches as I run and I about fall over.
The walk belt should be tight (about 1.5" to 2 " when lifted at the edge), if not tighten screws at the rear. If the belt is tight enough then pull the front cover off and check the front roller. Sometimes the plastic drive pully slips on the front roller. If it only stops while you are running and is fine when you walk, i would go to the front roller.
Nov 02, 2010 | Proform 680 LT Treadmill
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
I am having problem with the belt moving when i am trying to walk/run on treadmill
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
Good Luck!
Mar 04, 2010 | Proform 760 CrossTrainer Treadmill
Belt stops when i walk on it
with item going 2mph, stand on foot rails, hold on handles,with one foot try stopping walking belt-look at front roller while doing this-if walking belt slips around frt roller, its the walking belt loose. at each corner there is an adjustment,with proper allen wrench, turn CLOCK WISE one turn EQAULLY on each side!! Then recheck,keep doing this untill it quits slipping-Small moves is best don't crank.
Now on other hand if walking belt Stops with frt roller, its the MTR dr. belt under the hood, to tighten,with 2 9/16th wrenchs, I loosen mtr mount bolt,with one hand apply pressure to mtr, retighten, or have wife apply this pressure with her foot,but don't over tightn-u want to turn belt 1/4-1/2 inch on side. Also check walking lube under walking belt!!
Jan 06, 2010 | Proform 760 CrossTrainer Treadmill
PROFORM RUNS BUT WHEN I STEP ON IT EITHER SLOWS DOWN OR STOPS MOVING AT ALL
Belt needs tensioning up on its adjusters or the motor drive gear has come loose and needs tightening back up.
Jul 31, 2009 | Proform CrossTrainer Treadmill
May 13, 2009 | Proform CrossTrainer Treadmill
Treadmill seems to slip while running,
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
75 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
