Question about Electrolux Refrigerators
Where do the wires on the 240v element conect to on my Electrolux RM 4270 fridge?
3 Suggested Answers
SOURCE: Electrolux RM 4270 caravan fridge
Thankyou for your assistance, but i found the solution with electrolux direct.
Hope to use your site again sometime.
Posted on Aug 05, 2008
oscarn
  • 110 Answers
SOURCE: how to convert 110v to 240v dometic 2652 fridge ?
Simple solution would be to step down the 240V to 110 V with a transformer .
Posted on Jul 02, 2014
Where is the heating element for the 12 V side on Rm 2510 3 way Electrolux
two black wires from lower control board to chimney the one marked 12 volt on board
Mar 29, 2018 | Electrolux Refrigerators
Electrolux rm 4200 repair
Try 1,000 Volts, proceeding up to 10,000 Volts. I'm sure something will happen.
Sep 18, 2014 | Refrigerators
How to convert 110v to 240v dometic 2652 fridge ?
Jul 01, 2014 | Dometic RM2652 Refrigerator
Three year old Dometic RM 2555, 3 way Frig/freezer has failed on 240VAC however works on Gas. I suspect the PCB is faulty
My rm2555 has just failed on 240 volt. But not 12 volt.
It turned out to be the 240 volt element .
Fairly easy to replace. If you have a multimeter test the resistance, mine was open circuit.
Does yours work on 12volt?
The two heater elements (ie 12v and 240v ) are on the right when viewed from behind with four large wires coming out, plus an earth wire. There are labels on some of the wires. The 12 volt conects into a terminal connector, where as the 240 volt is fitted with spade connectors and is attached to the printed circuit board, under the white plastic cover. The elements are "L" shaped and are just pushed down in down next to each other. The cover seems to unclip fairly easily to enable removal.
Hope this helps.
Mark
Dec 26, 2010 | Dometic Refrigerators
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Jul 07, 2010 | Electrolux Refrigerators
Aug 04, 2008 | Refrigerators
We have caravan electrolux rm 4230 light is on for 240 chilling, but fridge does not cool. appliance does however cool fine on gas.
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Jul 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
44 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
