Question about Garden
After storing my 2014 skag over the winter, it won't start. Just cranks and cranks and cranks. Has gas in it but will not start.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
I would suggest making sure it has fresh (new) fuel. I would also check and clean the air filter (sometimes little creatures will nest in there). Change the fuel filter, they have a tendency to gum up over the winter. I would also suggest replacing the spark plug.
Posted on Apr 24, 2015
What would be wrong when my car has gas, but no spark?
2001 Sante Fe Won't Start, Cranks But No Spark. - Hyundai Forums ...
www.hyundai-forums.com/...santa-fe/112601-2001-sante-fe-won-t-start-...
Jul 23, 2010 - 10 posts - ‎3 authors I have a 2001 Hyundai Sante Fe that died on me while driving down my street. ... Thecar has many other unrelated problems and I am not sure I want to ... may be causing my two cylinder no spark and alleged fuel problem? 2006 Santa Fe 2.4 Engine swap-no spark
Sep 24, 2012
No Start 2.4L Engine 2004 Manual
Nov 26, 2011
Good Crank/Have Fuel pressure/NO IGNITION
Oct 9, 2011
Car Cranks But Will Not Start
Jan 16, 2008
More results from www.hyundai-forums.com
Engine cranks but won't start.What should I do. - YouTube
? 9:37
https://www.youtube.com/watch?v=jsQcLya1YLQ
Jan 24, 2014 - Uploaded by jimthecarguy
No Start Cranks Ok No Injection Pulse 2002 Hyundai Accent Easy Step By Step ... and car cut off, but would not restart. it sounds like it is starving for fuel. ... hi nice video man . i have no sparkno fuel .u think its the main? it was ...
Nov 26, 2015 | 2001 Hyundai Santa Fe
Is there a fuel/water separator on a 2014 gmc sierra 1500? MIL comes on for a bit then off. code p2269 stored.
Fuel injected gasoline engines have fuel pump in gas tank. Pump is supposed to "emulsify" (fancy word for "mix") fuel and water to help prevent a localized build up of water at bottom of tank. But ...water and gas don't mix and if you have too much water (caused from condensation ...especially in the winter ...and consistently keeping your fuel at low levels) things don't work so well. Dry Gas ...ancient stuff from carburetor days and frozen fuel lines ....get some, a couple or three bottles at least, and pour into your gas tank then fill up. Dry Gas is essentially (methyl?) alcohol that will break up the water and allow it to better mix with the gas.
Feb 19, 2015 | 2014 GMC Sierra 1500
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
2002 Ford Explorer ran out of gas put gas in and won't restart. replaced fuel pump and fuel filter still won't start. Cranks but won't start
Most Fords have a fuel reset button. When you ran out of gas you tripped the circuit. Most of the time the button will be on the passenger side by the kick panel. The exact location should be in your owners manual or your local library or auto parts store will have a copy of one for your specific vehicle.
May 08, 2012 | 2000 Cadillac Seville
6.75 won't start can puy gas in spark plug hole and it runs till gas is burned
You need to clean the carburetor, make sure to get the main jet in the middle. If you have a carburetor on the tank, replace the diaphram and gasket while you have it apart or you will be there again later when it goes bad.
Remember to not store it with fuel in it over the winter and do not use old gas next spring.
Oct 23, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How do you store lawnmower for winter? do you
mix a fresh gallon of 89 octane with a fuel stabilizer. run for a few minutes. the battery will need a trickle charger.
Nov 06, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Cranks but wont turn over
Did you drain the gas out before you stored it.
If its carb model, then the carbs probablt need taken off and cleaned.
If it fuel injected, the screens are probably plugged up....dump the gas and try fresh gas
Mar 31, 2010 | 2003 Suzuki VL 800 Volusia
Can't get my Ryobi edger to start. Bought it last year. Only used it three times. Stored it for the winter. Just won't start. Is there a trick?
Is this a 2 stroke or 4 stroke motor? If 2 stroke, are you remembering to press the primer bulb before starting? When you stored it for the winter did you leave the gas in the machine? If you did, then empty the gas and refill with fresh gas.
Jun 13, 2009 | Garden
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
