Question about John Deere Garden
Gas is not going to fuel filter - John Deere Garden
  • John Deere Master
  • 2,478 Answers
Make and model Take fuel line off on filter tank side. And fuel cap off, see what happen.
Posted on Mar 29, 2015
  • Jim Kennett
    Jim Kennett Mar 29, 2015
    did that an nothing happened. applied air to line and bubbles appeared in tank, but still no gas
Fuel filter won't fill up
Fuel pump weak, fuel filter dirty, carb./injectors clogged, bad gas?
Jun 14, 2013 | Cars & Trucks
Where is the fuel filter located on a 94
look under rear vechicle where fuel tank is, you will see fuel filter.let vechicle sit over night fuel will return to fuel tank there wont be much fuel pressure when you replace fuel filter gas wont spray all over the place go to dealership buy tan oring that go on fuel filter dont use black universal o rings gas will destroy it. lubricate new o ring with few drops clean engine when instaaling o ring on fuel filter fuel line.
Feb 10, 2012 | 1992 Chevrolet Corsica
Where is the fuel filter located and how do I change it ?
Thanks for choosing FixYa and welcome to the site. Your fuel filter is usually the on the same side as your gas cap. Go to the cap and look under the car. You should be able to see the gas lines. Follow the gas lines. Some will split off to the gas tank and the others will go toward the front of the car. You should be able to see your fuel filter on these lines. It almost looks like a small oil filter. Now, observe the filter and find the bolts. You need to remove both gas lines to the filter. You will have one in the front and one in the back. There will be a little gas coming out, so that is normal. Once you take off both gas lines, take off the bolt that holds the filter up. It may be two bolts. The filter should come out and you can replace it with the new one.
Apr 24, 2011 | 1997 Pontiac Bonneville
Were is the fuel filter and is the fuel pump in the gas tank
the fuel pump is in the gas tank and the fule filter runs along the bottom of the Driver side..if your looking at the gas tank follow the gas lines that go toward Eng. you will see the Fuel filter
Dec 30, 2010 | 1996 Dodge Caravan
2002 yukon hard to start, where is the fuel filter and how to replace it.
FIRST RELIEF FUEL PRESSURE BY REMOVING GAS CAP REMOVE FUEL PUMP RELAY START ENGINE UNTIL IT DIES LACK OF FUEL. FUEL FILTER IS MOUNTED TO THE RIGHT FRAME RAIL.NEAR THE FUEL TANK.YOU NEED A FLARE NUT WRENCH TO LOOSEN FUEL LINE AT FILTER AND A ADJUSTABLE WRENCH HOLD FILTER LARGE NUT WHILE LOOSEN FUEL LINE THIS KEEP FROM TWISTING FUEL LINES WHILE LOOSEN FUEL LINE.BESURE TO GO TO DEALERSHIP AND BUY NEW O - RINGS AT FUEL FILTER LINES.LUBRICATE NEW O- RINGS WITH CLEAN ENGINE OIL.WHEN INSTALLING NEW FUEL FILTER DONT OVER TIGHTEN FUEL LINES CUTTINGTHE O -RINGS AT FUEL FILTER.IF SO THEY WILL LEAK GAS WHEN YOU START UP ENGINE.WHEN DONE CHECK FOR GAS LEAKS WHEN DONE DONT DRIVE UNTIL YOU CHECK FOR LEAKS FIRST.
Aug 16, 2010 | 2002 GMC Yukon XL
Need to find the fuel filter on a 2000 mitsubishi galant
The fuel filter is located in the gas tank. You have to take pump out of the tank to change out the fuel filter .
If you're going to replace a fuel filter make sure you have the right tools to do the job (Don't use a screwdriver to pop a pressure clip connection) And pop the gas cap before you pull the filter... It's better to get a drizzle of gas than to get a pressurized shower.
May 02, 2010 | 2000 Mitsubishi Galant
Thre no gas going thru the gas line
If the fuel filter is clogged up, even the fuel pump is working, fuel is not going to be delivered to the gas line. Replace the fuel filter first if pump is working. If pump is not working then have to troubleshoot why to address the correct repair, relay or pump or circuit control fuel pump besides the relay.
Oct 14, 2009 | 2004 Volkswagen Jetta
My gas tank leaks and my fuel filter is clogged
The mechanic should check on the leak of the gas tank and locate the leak and weld it .Then if there are leaks also in the fuel lines or hose.The fuel filter should be check also if already worn out or destroyed they should be replace .if clogged or dirty it should be cleaned. there are two fuel filters the primary filter and the secondary filter . That's why you have to do it twice , the cleaning.The clogged that happens on the fuel filter are cost of dirt that are found in the gas that have been stuck in the filters . So that the gas or fuel that will go to the engine is clean to be compressed by the engine.
Aug 31, 2009 | 1984 Ford Crown Victoria
Cannot get 1987 chevy van 20 to keep running... stalls out
Best do a fuel pressure test. Should have chg. fuel filter from the get go. The only other filter is on the end of the fuel pump in tank. Bad gas and dirty gas will plug up fuel filter, hense burn pump up.
Apr 11, 2009 | 1987 Chevrolet G20
No power when going up hill
when was the last time the truck had a tune up? plugs wires air filter fuel filter and if it has over 40,000 miles a new drivebelt put some STP gas treatment in the gas tank and if this helps the problem replace the fuel filter; the fuel pump is in the gas tank and the fuel filter is underneath the truck normally on the driverside just under the door or the passanger side just in front of the rear tire in the frame
Jan 19, 2009 | 1996 Ford Explorer
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
