Question about Refrigerators
Does the temp control knob in the freezer compartment pull off or screw (turn left or right) off?
  • Lloyd Kallio
    Lloyd Kallio Mar 31, 2015
    While waiting for an anwer I pulled it off with a pair of vice-grips
    Top Expert:
  • Refrigerators Master
  • 50,169 Answers
Just pulls off
Posted on Mar 31, 2015
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
I have an older side by GE refrigerator model # TFX24R. The freezer is fine, but the fridge isn't getting too cold. Any suggestions??
You may have ice formed in the passage between the freezer and the refrigerator. You have to remove the plastic panel in refrigerator side. (pull temp control knob straight off, then tilt plastic panel forward from bottom. Should come off with a little wiggling). Next remove one screw just above where the temp knob attached. this will allow the left half of the assembly to pull toward you. It will want to stick to the right side of the assembly (were the light buld is) so just gently encourage it to come out. Once out you will have a very simple device in you hand made of foam and plastic. rinse under warm water and get all the ice out of it. Dry it and put back in. replace parts in reverse order.
See if that helps!
Mike in Tucson, AZ
Jul 08, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
2006 Suzuki forenza with no climate control. How to remove knob without damage and/or change temp from engine compartment?
The knob cover easily pulls off. To remove the entire control, pry trim panel off, then remove screws that hold on controls and remove it.
Nov 20, 2009 | 2003 Suzuki Aerio
Maytag MZD2665HEW ADC replacement
You will find the defrost control board inside the panel that contains the two turn knobs where you control the temp inside both compartments. It's inside your fresh food section of your unit. Pull the two knobs off, take the screw out of the side and remove plastic piece. Between the two temp controls there is a square box. The board is located inside the box. Take box apart and replace board.
If you would like a parts blowup of the unit, go to www.partselect.com and enter your model number. Select the Control panel to the left. This will give you a blowup of the parts.
Please rate solution
Sep 10, 2009 | Refrigerators
Hotpoint FFA70P Bottom freezer not working
HI The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 07, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Kenmore Elite bottom freezer suddenly stops making ice.
hi The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
Step 2:
Step 3:
Step 4:
Sep 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrigerator not cooling
you need to locate the defrost timer should be in the same box the temp control is some have little knobs some have funky little screw heads like the screws in bathroom stalls should be a hole in the housing where the thermostat is turn it slowley clockwise till you hear thu unit come on if it before you do that smack the temp control first a couple of times make sure its not sticking then let me know
Feb 16, 2008 | Refrigerators
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
