Question about Samsung Cell Phones
I have a samsung sch i200pp touch screen phone..the buttons won't move n is always frozen..even when I did a master factory reset it still doing the same thing
  • Samsung Master
  • 2,045 Answers
What do you mean "don't move"?
Posted on Mar 30, 2015
5 Suggested Answers
Achabacha
  • 113 Answers
SOURCE: factory reset how to?
In the Settings Menu of your handset, their's an option to RESTORE FACTORY DEFAULTS / RESTORE SETTINGS.
Select it and your handset will be resetted to Factory Settings.
Posted on Apr 24, 2009
  • 14 Answers
SOURCE: my samsung pixon touch screen has frozen
Did you try taking the battery out then putting it back in?
it stops it from freezing
Posted on Jul 27, 2009
SOURCE: Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Posted on Sep 30, 2009
SOURCE: My LG chocolate touch 8575 touch screen is frozen
Go get a ******* new phone the chocolate is a piece of ****
Posted on May 15, 2010
Master reset password for sch-s720c
i dont understand your question ? do you have a password on to get into your phone and you have forgot it ? ..if you have a password on and you have forgot the password then you will have to reset your phone to factory default ( loosing everything ) to do this you need to turn the phone off. now hold down the volume up button and the home button on the front,keep holding these buttons and turn the phone on , keep holding them buttons while the phone is turning on,you will get a menu then release the buttons. you can now scroll down to factory restore
May 15, 2015 | Samsung Cell Phones
How does one hard reset a Samsung r631 cell phone
I just need to warn you that doing a hard reset will erase all your save files and application on your phone. It will be back to factory default settings.
To do a hard reset on your device :
1. Make sure that your phone is turned off
2. Press and hold the volume down + menu + power button
3. Wait for the samsung logo and release the buttons
4. You will see something loads on the screen and the recovery menu will come out
5. Use your sensor to navigate and select "wipe data / factory reset.
6. And press down on your sensor pad to confirm
7. Wait for the process to be completed and your done.
Jan 02, 2015 | Samsung Messager Touch SCH-R631
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
My samsung sch-r710 touch screen is unresponsive. Will a hard reset fix the problem? How do I perform a hard reset?
try to calibrate the touch sensitivity setting before you reset it this always work in any case.nno need to to do a hard reset
Aug 14, 2012 | Samsung Lands Phones
The touch screen is completely frozen i cant do anything but receive and make calls using the keyboard what can i do?
Take the battery out for about 60 seconds then place it back and turn the phone on. If that doesn't work, you can try a master reset. This will erase all data on the phone and restore it to factory condition. To perform master reset, make a call and dial *2767*3855#. Hope this helps.
Regards,
Matt
Apr 15, 2011 | Samsung SGH-A877 Impression Cell Phone
How do i erase memory from it
reset to factory settings and ur memory will be erased.
Try this:
Samsung Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen.
Hope this helps.
Regards
Jul 31, 2010 | Samsung SCH-u340 Cellular Phone
Is there a way to master reset a samsung SCH-r211 phone? And can you direct me to a source for secret codes and functions of this model of phone?
This seemed to fix a glitch I was having with mine.
How Do I Reset My Cricket SCH-R211 Phone?
To reset the handset, to the factory default settings, follow the steps below:
  1. From the standby screen, press the left soft key for Settings
  2. Select Phone Settings (5)
  3. Select Security (3)
  4. Enter the lock code, default password is the last 4 digits of cell phone number
  5. Select Reset Phone (4)
  6. Press the left soft key for Yes to confirm resetting the handset to factory default settings
Note: Reseting the handset, to the factory default settings, will not delete any contacts
Source:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?SITE_ID=22&PG_ID=557&PROD_SUB_ID=799&PROD_ID=1597&AT_ID=149386
Dec 26, 2009 | Cell Phones
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
