Question about Samsung ML2165W - ML-2165W Wireless Laser Printer
Blinking lights wps and top light keep blinking
  • Samsung Master
  • 5,631 Answers
Check if it has paper stuck inside
Posted on Apr 02, 2015
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
Apr 05, 2015 | Belkin Computers & Internet
Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
Jan 06, 2015 | Computers & Internet
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
Wps light is out and emails not coming
Is there a way to get the light to turn off, and the WPS to be disabled by actually just pressing the button in some manner I am not doing?
If this is the normal functioning of the router, does Netgear plan on providing a way to just flat out disable WPS in a future firmware upgrade?
This router blows away my previous Linksys wrt54gl and Asus routers. I would like to keep it, but with the constant traffic which I have near me, I really need some way to turn the WPS off and keep it off.
Dec 18, 2013 | Computers & Internet
Wps button
The front of your Actiontec modem has a button and light for Wi-Fi Protected Setup (WPS). If that button was pressed or the WPS process was started, that button may light up or blink.
Aug 16, 2013 | D-Link DIR-625 (790069292637) Wireless...
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
Does my WRT160N have a WPS button and if so, where is it?
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Jul 06, 2011 | Linksys WRT160N Wireless Router
There is a green light on on top and after i push the wps button a red light blinks for a while and then stays on any ideas the laptop that has been used with this router is not getting a connection now...
WPS means Wi-fi Protected Setup its a kind of wireless security for the router. There are two methods of activating it either by push button(Which you tried) and other is manual for that you can log into the Router setup page using "Http://192.168.2.1" in the Internet explorer and enter the pin code printed under the router. You should click on "Wi-fi protected setup" towards the left side of the page and leave the password field blank and click submit and enter the code and click on "Start" or Apply changes. The reason why it didnt work through the button is probably because your laptop might not be in range or switched off. It has a utility installed on your laptop which recognizes the connection and let it protect using WPS.
Hope it helps. Please feel free to contact us for further assistance or information.
Dec 16, 2010 | Belkin Basic Wireless Router
TOP LIGHT ON PRINTER KEEPS BLINKING - I'M UNABLE
This should help you. It details what the blinking lights mean and should allow you to diagnose what the problem is.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061319&lc=en&cc=us&dlc=&product=305980
Oct 13, 2009 | HP DeskJet 5550 InkJet Printer
Samsung ML2165W - ML-2165W Wireless Laser Printer Logo
361 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
