Question about Kenmore 90701 70 Pint Dehumidifier With Remote Monitor And Auto Drain Pump
Runs ok yet no water is condensed. no freon. how do i repair the leak & recharge the system?
  • Kenmore Master
  • 3,382 Answers
Call a refrigeration service tec
Posted on Apr 02, 2015
How do you add more freon?
Make sure the thermostat sensing tube is in it's place first. The thestat can be faulty too. The likely hood of Freon leaking is remote but possible. You need a whole bunch of special equipment to find the leak, repair it and recharge the system.
Aug 27, 2014 | LG LP1111WXR Portable Air...
No water in the catcher
its probably low on refrigerant if its a newer model it will be R134a refrigerant,if older R-22 freon,the newer ones like to lose their charge,dependent upon what you initially paid for the unit will govern whether to repair or junk,usually between $50-$75 to top off more to repair and recharge
May 11, 2012 | Dehumidifiers
My dehumidiyer fan runs, condensor seems to work but the coils do not get cold so thus no condensation. what can i do to get my humidiyer working?
typical for most brands of dehumidifiers.after 2-3 years use the refrigerant/freon leaks out and they wont cool,you can have it recharged,but quite expensive as i charge between $50.00 to $75.00 to do this
Aug 07, 2011 | Whirlpool AD40DSR Dehumidifier
Not building up much water in the bucket set at 35 sometimes 50 small amount of condensation on top of machine
its low on refrigerant,this is normal after about 2-3 years use,it costs about $50-$125 to evacuate old refrigerant and seal and recharge system with new proper amount of refrigerant being it R134a or R22 freon
Aug 01, 2011 | Kenmore 54501 Dehumidifier
Not accumulating water and condensation on top
Your unit is low on freon from a sealed system leak. The sealed system should have a 5 year warranty. You need an authorized LG tech to write it up for an exchange. Check your manual and call an LG service dealer.
Nov 15, 2009 | Comfort-Aire BHD-501 Dehumidifier
My kenmore dehumidifier compresor runs the fan runs but no water in the bucket . Compresor freon lines both same to have the same tempature ( flow and Return ) . Is a freon charge the answer ?
More than likely not. I would start by making sure all coils are clean, (both evap and condenser) and to make sure airflow is not being obstructed. Most factory charges appliances don't leak refrigerant and therefore should not have to be charged during there useful life. Hope this helps
Sep 22, 2009 | Kenmore 53509 Dehumidifier
Same Problems as Everyone Else
I have a Danby DDR 458EE dehumidifer that I purchased May 27, 2008.
Used it for the summer and stored it until May this year. At the end of July of this year it started not working. It freezes up. Called Danby, they told me it was out of warrenty and to take to a repair shop. Problem being it was leaking freon so have it recharged. Called the repair shop and they explained that it is a closed system and if it is leaking Freon, they can not recharge it until the leak is found and repaired. It's against the law to discharge freon in to the atmosphere. Stated cost to repair it would be greater then buying a new one. Called Danby back and explained what repair person said. Still waiting to see if they will give me a pro-rated refund.
Jun 13, 2009 | Danby DDR6588EE Dehumidifier
No water in the bucket
You most likely have a freon leak, or the compressor is not running. When the machine first turns on you should be able to see if the compressor is running or if it is just the fan. If the compressor is not running it does have a start devise and a relay on it that can be replaced. If the compressor is bad, most units have a 5 year warranty on the compressor, so contact the manufacturer for warranty service. If the compressor is running you have a freon leak, and it would need to be found, repaired and the freon replaced. This is a large repair, estimated charge for a leak repair would be around $149.99 The reason is the long time it takes to find the leak, and all the parts needed. Drier, valve, freon, etc.. Good luck, and I hope it is only the relay. You can get those relitively inexpencively. 3 in 1 kits are also good for a hard to start compressor. They give the compressor a little more kick to start it. They are about $28.00 and easy to install once you are to the compressor. I hope this will FixYa.
Mike
Sep 27, 2008 | Haier 45-Pint Dehumidifier
Dehumidifier
if the compressor is running and the fan is running then the unit has a sealed system leak that will need to be repaired and recharged to function properly
Jun 03, 2008 | Kenmore 5230 Dehumidifier
Edison 40 Dehumidifier
Old post, but in case someone stumbles in here like i did, I need to point out that if an A/C needs to be recharged, then there has to be a leak somewhere, there is no use on recharging unless you find the place where is leaking.
Jun 01, 2007 | Edison 40 Pint Dehumidifier
Kenmore 90701 70 Pint Dehumidifier With Remote Monitor And Auto Drain Pump Logo
197 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
