Question about Haier HWD1000
Haier HWD 1000 trying to dry clothes error message u04. What does this mean?
Just moved, no instruction Manuel. Trying to dry clothes error message u04. How do I dry clothes? Washer is OK the dryer is not working
  • 5481 Answers
SOURCE: how do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Posted on Jul 12, 2008
  • 43 Answers
SOURCE: Haier Not Drying
most likly to be thermostat if you remove the lid you should see 2 little round thermostats on top somewhere some stats have a reset button on 1 of the thermostats if there is press it if it clicks try it on a dry to see if it works
Posted on Nov 11, 2008
aborcass
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
ZJLimited
  • 17970 Answers
SOURCE: i keep getting error code u04 when i try to use my machine...what does it mean
Error U04 means the door is open.
Put your knee against the door handle and press it against the handle until you hear a click. The machine should start filling within a minute.
This is a problem I had start occurring about a month after I started using the machine. You will soon do this for every load, a minor annoyance on a cheap machine.
I hope this helps, and remeber leave some testimonial comment. Have a nice day and thank you for using Fixya.
Posted on Nov 13, 2011
SOURCE: Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Posted on Feb 04, 2012
Replaced power control board, still getting error messages IDE5, U04, do2. Help!
Hi, did you check the codes before you replaced the board? Have the faults only been displayed since the replacement?
Jul 14, 2015 | LG DLEX3360R Dryer
My Haier HWD 1000 won't plug in without popping the outlet. It's Not the outlet, everything else works fine in it. and the washer pops ANY outlet.
sound like a wiring problem that keeps tripping it out poss water in wiring or a loose wire somewere have it checked by someone
Oct 13, 2014 | Haier Washing Machines
Clothes not getting clean
dryers only dry.............washers get clothes clean...
cheers
Sep 07, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hello, i am using Haier washer dryer HWD-D1200TXVE that is 1 year old, after a full cycle (pre-wash) the machine gave an error 12 and did not perform drying because water was not drained. I opened the...
Look up the mfg website and see if they have a troubleshooting page or a support group. It may still be a warranty item check that as well
Oct 20, 2013 | Washing Machines
I have a haier hwd 1600 that is giving a error code 13 what does that mean and can i reset the machine or do i have to call a service tech
I service this machine before. There is no service manual for any Haier products.
You might want to change these parts out in the unit: Main PCB board, Heater Element, Thermostat and the Condenser.
Mar 25, 2013 | Haier HWD1600 13-Pound Combo Washer Dryer
I keep getting error code u04 when i try to use my machine...what does it mean
Nov 13, 2011 | Haier HWD1000
Error 4 ON HAIER WASHING MACHINE.
Error EC4 refers to the temperature of the air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
Ask the technician to
repair it.
Alternatively make a custom cycle with no drying cycle and hang dry the laundry. I usually do this myself as opposed to listening to it groan for 2-3 hours.
Aug 10, 2010 | Haier HWD1000
Haier HWD1000 Logo
78 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
