Question about Fosmon 1x4 HDMI Splitter Hub Full HD 1080P with HDCP Support Black
At this time I have two devices connected to the splitter. Everytime I turn one of the TV's on or off I have to do a power reset to get the splitter to feed the remaining device.
The devices are flat screen TV's.
  • Michael Berkshire
    Michael Berkshire Mar 31, 2015
    My question, is this normal or not do I need to get another splitter amplifier?
Lg 42px-4dv/ea sustain pcb fails after 6 hrs running.
Try hard resetting;
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 21, 2008 | Televison & Video
Church has two tvs and we hook them up to our Macbook pro and use a progam called Mediashout to play lyrics. When we have both tvs connected through a splitterbox they blink green and the image trembles....
HDMI comunicates between the output device and the tv. The two components sync the comunication pulses. By conecting the second tv the pulses are out of sync. Somehow one tv must become Master. Is there a function on tv2 to turn off the sync puls? Maybe there is a device that will allow 2 tv's to connect to 1 device but it will be more than a splitter because it will have to sync. with the output device and then seperatly sync with two tv's. Good luck
Sep 18, 2012 | Televison & Video
Hello,I have purchased a digital converter to connect to my tv to receive local stations,My question is,What do i need to connect all 4 tv's that I have to the converter? or Do i need a converter for...
The converter has only one tuner, this means it can only tune one station or channel at a time. The output of the converter is usually a single coaxial cable jack. The output is generally a user selected channel - often Ch 3 or Ch 4. When you connect the output of the converter to the antenna input of the TV, you set the TV channel to match the setting on the converter (again, Ch 3 or Ch 4).
You could install an amplified splitter to split the output of the converter and run a cable from each TV to the splitter, more on this amplified splitter, later. Set all the TV's to the same channel as the converter output (Ch 3 or Ch 4) and you would be able to watch whatever the converter is tuned to. This means ALL the TV sets must watch the same channel. What is showing on one will be shown on all. This may not be a problem if you live alone and own 4 TVs. You could simply turn one TV off when leaving a room and turn on another when entering a new room. This will be a problem if there are two or more people in the house that wish to watch different programs at the same time. To accommodate everyone, you would need as many converters as there are different programs that are to be watched on different TVs at the same time - 4 would be a good choice to provide the greatest flexibility of tuning for every TV.. You would simply install the additional converters on the other TVs just as you did with the first TV.
If you wish to use a splitter to divide the output of the converter to several different TVs (or have a single antenna and want to send the signal from it to several TVs for that matter), an amplified splitter is highly recommended. A standard splitter only divides the signal and has no provisions to boost the signal from the antenna. The more ways a signal is split, the less signal there is to supply to the TV sets. The result is a snowy picture. An amplified splitter not only splits the signal the way a standard, non-amplified splitter does, but also boosts the signal from the antenna to each TV. This provides a much stronger signal to the TV which results in a better picture. Pick an amplified splitter that has enough output jacks (based on the number of TVs you wish to connect).
I hope this helps and good luck!
Sep 13, 2011 | Televison & Video
Hi, when I turn off the power for the tv, the power keeps turning back on by itself every time I turn it off
I had the same problem with mine (same model) purchased Oct. 2010. I also have a Sharp 52 LCD. I was using an HDMI Splitter purchased from Monoprice to slave the Toshiba to the HD output of Dish's VIP722 receiver, because the 722 outputs only one HD video signal and on a separate RG6 connector outputs standard definition for a second display. Well, as the bedroom TV is usually tuned to the same channel as the family room TV, I decided slaving the VIP722 HD output was a better solution than paying Dish a monthly fee for a second receiver. To shorten this story; the problem seemed to be caused by the HDMI splitter. I purchase a higher price splitter from Comp USA and when I connected it the problem disappeared. I hope this helps you. Oh, I feed the outputs of the splitter to two separate Yamaha (models 667 and 367) AV amps and from the amps to the TVs.
Dec 12, 2010 | Toshiba 46G300U TV
I have a tm502g modem and it keeps disconnecting from the internet at various intervals. It will connect for awhile than it disconnect. After it disconnects I have to turn my computer off and unplug the...
The 502 cannot be reset by unplugging it. It has a battery. There is a reset right in the middle on the back. There is a pinhole and you push a toothpick or unrolled paperclip inside the hole and it resets. There are a couple of issues here. Does the EMTA (modem) turn off and reset, knocking you off or does your computer go off while the modem is fine (you will still have phone). If you still have phone then you have another problem. You have a router or a bad ethernet cable. If the modem is going offline I bet you have a splitter on the coax coming into your house. One lead from the splitter goes to your tv and the other your modem. If that is happening it is your splitter. It isnt bad, you just want to re-seat your cables into that splitter. Just undo them, push them in and out of the splitter a few times and your modem will go back online for another year or so
Oct 08, 2009 | Arris Computers & Internet
Hitachi 50vs69a blue oval circle in the center of the screen
Just try to reset HDTV. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
7. Turn on the TV.
Regards:
VOTIT
Jul 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The screen turns on hen off
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Sep 14, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Flashing boxes on screen
Regardless of what the satellite company says, I would find a way to try another satellite reciever to start with. I have seen this from cable boxes and satellite recievers many times. I have also seen this with a bad LNB, distribution amplifier, or a bad active splitter, or a bad cable, or a bad connector.
There is a data loss somewhere, and the set is seeing what we call aliasing. This is a loss of data, and it shows as blocks.
It is possible for your set have internal aliasing if there is a fault on one of the processor boards. The only way you will easily know if the problem is external or internal to the set is to try another source.
From your description, if other sources work with the set, then this strongly rules out the set. To easily know if the fault is on the input that the sat reciever uses, if possible swap the position with the DVD player.
On the sat system, a defect in the reciever, the LNB, or any LNB splitters or a relay, or a bad connector, can also cause aliasing because of a signal loss.
Jerry G.
Apr 30, 2008 | Toshiba 50HP66 50 in. Plasma Television
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
Fosmon 1x4 HDMI Splitter Hub Full HD 1080P with HDCP Support Black Logo
51 people viewed this question
Top Fosmon Televison & Video Experts
Electro Med Services...
Are you a Fosmon Televison and Video Expert? Answer questions, earn points and help others
