Question about GE Microwave Ovens
Why has my GE Spacemaker microwave oven stopped heating?
Light still comes on and tray rotates
  • GE Master
  • 2,992 Answers
How old? perhaps time to replace or find a lightly used replacement. It may be major, or minor, but the appliance service labor, and potential part may be more than the lightly used replacement.
Posted on Apr 11, 2015
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my ge spacemaker microwave oven stopped heating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating. Everything else still works - it comes on, the light comes on and the plate rotates and it dings when it done, but te food is still froozen.
Sounds like either the magnetron or its high voltage power source has failed.
It is extremely dangerous to work on the magnetron side of the power system. It CAN and DOES KILL!
Dec 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My ge spacemaker microwave oven stopped heating. light still comes on and tray rotates but it does not heat.
heatman101
Dec 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The round plastic tray is not moving, rotating and while I'm heating something there's a groaning noise?
heatman101
Nov 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 2001 GE Spacemaker #JVM1840CD001 that does not heat anything, but runs. What's wrong and how can I fix it?
If your microwave oven "works" meaning that your display, cooking tray rotates, and the light turns on when you open the door, but does not heat the food, the problem usually is with the magnetron circuit. If you hear a loud hum when you try to heat something in the oven usually means that the magnetron has failed. The replacement magetron is about the same price as a new oven, so you are better off buying a new oven.
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE spacemaker JVM1542 that is not heating the food, the noise level is louder, light works, plate rotates.
sounds like its not producing any high voltage for the mag tube, check your h.v diode, then your h.v. capacitor for being open
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
