Question about Bernina Sewing Machines
I'm trying to get my Grandmother's Bernina Favorit 740 running again. I cannot get the zigzag lever to pull down so buttonholes can be made. Any suggestions?
The zigzag lever that pulls down to work together with the fixed stops won't pull down. Believe me, I've tried. I even tried with a pair of plyers. This is an old machine and it hasn't been used for quite a few years. I've got it cleaned, oiled, and running again, but this lever just will not budge.
  • Bernina Master
  • 10,239 Answers
Awesome! Glad you were able to get it working. To loosen things even quicker, after oiling with penetrant, use a hand-held hair dryer to direct hot air into the internal sewing machine mechanisms. Even if you aren't able to lube the internal levers for the selector switches/knobs, the hot air will frequently free them up.
Posted on Mar 31, 2015
    Master:
  • Bernina Master
  • 470 Answers
The lever could be rusted in place; ie. the parts that move across/over each other when the lever tries to move down, don't.
Here is a list of Internet searches for Diagrams; not all of these will be for your exact machine but all are similar. Cast about and you can see how your lever is supposed to work.
Bernina 740 diagram Google Search
Posted on Mar 29, 2015
Testimonial: "I found this solution on another website: spray the part with lubricating oil, use a hair dryer and work the part until it moves. I was able to do this and it now moves great!"
Bernina virtuosa 153 doesnot maintain stitch lengh selected and throws a zigzag in with a buttonhole stitch.
any machine I ever used sews button holes with zigzag and very short ones at that .
Jan 05, 2017 | Bernina Sewing Machines
My Bernina 830 sewing machine will not do a zigzag stich
We are assuming that the zigzag width dial is at the widest position but the needle will not move laterally for zigzag... The following logic should be applied for Bernina machines 530, 730, 830, 930 machines with a guided motion zigzag cam.
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Sep 28, 2014 | Bernina Sewing Machines
I followed the direction, the pressed the peddle. My stitches are straight instead of zigzag.
For the buttonhole function, there is generally also a lever you must pull down to engage the function. If you DID pull it down, you may not have pulled it down enough, so that it wasn't engaged.
Dec 27, 2013 | Singer Confidence 7469 Mechanical Sewing...
Bernina Bernett 55 is stuck in reverse
make sure it's not in the buttonhole setting, and if the machine
isn't in the buttonhole setting and the buttonhole lever isn't down
then it would be a good idea to have the machine checked to see
why the machine ins stuck in reverse.
Dec 13, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
Singer curvy 8778 the needle is making the motions to stitch evenly, but the stiches to the left are missing, not the thread mind you. So a zigzag stich appears straight. I have done all the...
Call Singer at 1-800-4singer, sounds like a buttonhole lever problem. Is it like that on all styles of buttonholes? Check that out before you call them, and make sure that you pull the lever all the way down.
Apr 16, 2011 | Singer Curvy 8770 Electronic Sewing...
I am trying to make a buttonhole using the buttonhole foot and everytime i go to sew the machine beeps and will not let me sew?
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Nov 16, 2010 | Singer 7436 - INGENUITY
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
Bernina 740 favorit timing
boscados 740 840 940 742
Jan 12, 2009 | Bernina Activa 130
Sewing Machines Logo
69 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
