Question about Electrolux Washing Machines
Our Electrolux EWFLS70JRR0 washer has issues with door not unlocking and then occasionally stopping mid cycle. We have been limping along by unplugging and resetting lock but starting to see more random issues happening. Pretty much always run on "colors" wash setting so not sure if would happen in other wash cycle types. Machine is cleaned with Tide washing machine cleaner once per month.
    Genius:
  • Electrolux Master
  • 1,585 Answers
Check inter lock
Posted on Apr 12, 2015
  • Official Brand Answer
  • 4,342 Answers
Thank you for your post, friend!
Based off the information you have provided your Electrolux washer is displaying multiple issues. This sounds like a faulty control panel. You may need to disassemble your washer and test each electrical component for a proper diagnosis. This is not a simple DIY job and I would recommend seeking assistance from a professional technician for proper repairs. This will help you avoid any future issues. Hopefully this is helpful. -Matt
Posted on Apr 02, 2015
5 Suggested Answers
  • 22 Answers
SOURCE: My washing machine stops mid cycle
issue where washer stops and water won't drain might mean something is in drain area.
look at my issue "eco smart won't drain, smells hot" and see about the sock. I found one of my husband's socks so far down in the tub bottom that I couldn't see it when I looked between plastic outer liner and wash tub. Had to remove black motor/white housing on bottom of machine--which i had to replace cause it burned out. That is when I saw the sock and pulled it out through a quarter-sized hole.
Posted on Oct 21, 2008
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    RescueTech
    • 145 Answers
    SOURCE: washing machine makes buzzing noise
    Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
    Posted on Dec 18, 2008
    • 353 Answers
    SOURCE: i have an electrolux EWX14440W Washing machine,
    could be your door interlock is faulty
    Posted on Mar 02, 2010
    Everytime I start the washer it pauses halfway through the cycle why is that
    If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
    If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
    If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
    Main Control Board
    If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
    Timer
    If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
    Sep 28, 2016 | Washing Machines
    Aeg protex how to open door mid cycle
    To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
    Aug 16, 2014 | AEG Washing Machines
    The washer work but stop along the way,ie unable to complete the circle
    see this steps and fix it. God bless you
    Lid Switch Assembly
    Enter your model number to see parts for your washing machine.
    Help me find my model number
    Water Inlet Valve
    Main Control Board
    Timer
    If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Jul 13, 2013 | Washing Machines
    Washer heavy duty cycle issue
    Lid Switch Assembly
    Water Inlet Valve
    Main Control Board
    Timer
    God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
    May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
    Washer stops at rinse cycle and give the ul code F1
    see this causes and fix it. God bless you
    Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
    Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
    Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
    My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
    Hi
    It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
    Daniel
    Jul 07, 2011 | Washing Machines
    I have an electrolux ewx1440w washer-dryer. It keeps stopping part way through wash cycle. Cycle pause light flashes and door catch releases allow you to be able to open door. Machine will not restart...
    Hi I exactly have the same problem.. seems to be a common issue with this Electrolux series.. Thought that Electrolux was serious brand but obviously quality is leaving our world.. did you fix the problem and how..?
    May 20, 2010 | Microwave Ovens
    Electrolux washer stopped in mid cycle with clothes in will not empty water out. What do I check. Brian
    Most likely something caught in the pump. Coins and balls of lint are real common.
    Sep 17, 2009 | Washing Machines
    Whirlpool frontload duet washer F 6 problem
    hello cjkcp
    Welcome to Fixya
    You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
    F/06 Drive Motor Tachometer Error
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
    • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the Drive Motor
    • Check the MCU
    • Check the Wire Harness
    I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
    Thank you for using our service for advice.
    Please remember to leave a rating!
    Huuum
    Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    134 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
