Question about Sony NWZ-E436F MP3 Player
How do you remove hold function - Sony NWZ-E436F MP3 Player
How to remove or unlock the boot lock
You will need to get the "boot program" information
Function 91 enter. this will display 4 items of information press cancel to return to main screen.
This is an example of what will display.
TSPOS7 Program name
07A Program release
DLL-00 Download release number
T7AEPRM410 Boot program name and release number
7000011 Profile ID
you can now perform a boot function download, press Function 99 and enter. PW 028510 Enter , 9 enter, 6 enter, 2 etner, if prompts for host press enter, 1 enter, cancel, Configure terminal or call help co. put into boot function. this will take you out of boot function. unplug terminal and hold down void, offline and plug back in. hold down till 2 beeps ar heard. you will be asked to enter information you gathered from earlier.
May 27, 2014 | Hypercom T7Plus Credit Card Machine
How to remove "Press the Hold key to use in call Function"
hi , the hold key is on the right edige of the phone , with a "lock" symbol. Press the key , for a longer period ( 2 seconds ) to use the in -call menu features.
Dec 01, 2011 | Samsung Star GT-S5233 Cell Phone
I need to replace the passinger side tail light. It is cracked. I have a new one and need to know how to tremove and install the new one.
open the trunk and peel back the carpet so you can see the back site pf the tail light. first remove the bulbs and place them somewhere they cant get broken. locate the screws or nuts that hold the tail light lens on to the car. using the proper size tool remove any hardware holding the lens on which stand out because they are usually the only ones you will see in this area behind the carpet(ya cant missem). once removed replace with new lens replace the hardware and dont forget the bulbs and also a function test to make sure they work correctly before you hit the road. have a second person use all functions like stop,turn,reverse ect...if all functions work like they should you are good to go.
May 10, 2011 | Lexus LS 430 Cars & Trucks
My panasonic dvd player shows locked when I tried to eject. I can't eject tehDVD. My kids could have jinxed it. Model panasonic sc-pt550 TQ
There are two lock conditions for this device.
If you can't eject the disc:
Enabling removal of disc
1. Select the DVD/CD function.
2. At POWER ON condition, press and hold down the stop button and the power button on the player for at least three seconds.
(The message, "___LOCKED_" appears when the function is activated.)
If you can't operate the functions:
Enabling operation of selector and disc
2. At POWER ON condition, press and hold down the play button and the power button on the player for at least three seconds.
Hope this helps!
Apr 08, 2011 | Panasonic DVD-S52 DVD Player
My ti-84 plus it does not respond to the function + or - OR other function, & it come up to display very slow ,slow. thanks
Hi xvbanh,
You need to free up some memory. Try clearing your RAM. Your calculator should operate properly afterward.
Go to [2nd] [MEM] [7] [1] [2]
If your calculator still won't let you delete the RAM memory try the procedure below.
Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
reinsert the AAA battery and then turn the calculator on. The calculator should display the
message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
Jan 06, 2011 | Texas Instruments TI-84 Plus Silver...
What does error code E04-02 mean?
You've had too many fuser jams. Remove the fuser and inspect the heat roller and separator claws. After putting the fuser back in, you must do an lbp fuser reset in F9-6 mode. While holding down the function key, press original size ledger key. While holding those down, press the 3 key. This gets you into service mode. Press the stop key, then while holding down function key, press clear key to exit service mode.
Jan 05, 2011 | Panasonic Workio DP-3520 Copier
Instead of getting the @ symbol when I press shift +2 i get "
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail account.....no issue in Word docs.
Jan 13, 2010 | HP D8597A Keyboard
Unable to scroll through the function menu
switch off radio. not by the key but by the button. Hold down function until a menu comes on and then scroll through the menu using function button...
You cannot program this while it is on it needs to be in standby mode.
Nov 22, 2008 | Car Audio & Video
Multifuction switch
This is for a 97 but it may give you some help...
MULTI-FUNCTION WIPER SWITCH
REMOVAL
Tilt the column up and remove the six screws holding the lower column shroud.
Tilt the column down and remove the upper shroud Upper Shroud Removal
Tilt the column up and remove the one steering column tilt lever screw at base of lever. Remove tilt lever and lower shroud.
Using a screwdriver in place of the lever, tilt the column down. Remove the two mounting screws on the switch and remove the switch. Remove the wiring from the hooks and disconnect the two electrical connections on the multi-function switch. Remove the multi-function switch.
Jul 07, 2008 | 2004 Chrysler Sebring
Just Died!!!!!!
Remove the card from the device. Put the device into recovery mode to verify that it still functions. Recovery mode - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button If it does go into recovery mode, its not dead. Slide the hold switch back over, then turn the device off. Try turning it back on, if it functions, great. If not, reply with the message, or problem and ill go from there. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
Sony NWZ-E436F MP3 Player Logo
54 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
