Question about Dell Inspiron Computers & Internet
Can't seem to get any sound happening. I have no speakers but it is plugged into a TV. Also have HDMI cables, they get me the sound but I can't get a pic
  • Official Brand Answer
  • 560 Answers
Tracy Adkin,
Which Dell Desktop are you connecting to the TV? What is the specific video card do you have as well?
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Mar 31, 2015
My Toshiba 62hm195 DLP HDTV's HDMI ports have been losing sound intermittently. Both HDMI ports while connected to multiple devices (HDTV cable box, Panasonic Streaming Player) lose sound intermittently...
Your problem is in the streaming player. It is not keeping up and when an HDMI loses connection it will not auto find it again. To verify this take the Panasonic out of the loop and see if this fixes it. I love HDMI but it is touchy
Feb 18, 2015 | Toshiba 62HM195 62 in. HDTV DLP TV
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Audio Players & Recorders
No sound. Tried disconnecting/reconnecting all input/output HDMI cables. Only computer is connected via RCAs (for sound only). No sound at all. Audio works on HDTV, which is going from cable box,...
Did the speaker relays light up ? and did you hear the third speaker relays ON clicking sound? If both no, DSP problem. If both yes, DIR problem. If the speaker relays lit up but NO speaker relay clicking sound, check relay driver +24V power supply.
Sep 17, 2017 | Yamaha RXV467 Receiver
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
I just bought a Yamaha 5.1 system with rcvr RX-V365 i have HDMI to tv then HDMI to RCVR then another HDMI to DTV. Problem cant seem to get picture AND sound together through RCVR. depending on what setting...
RX-V365 doesn't support sound over HDMI. It can switch the video+audio from HDMI in to HDMI out, but can't play the sound through the speakers. You need to connect the audio separately via optical or coax digital cable.
Mar 19, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
No sound when using Panny plasma with RX-V3800
Let me see if I understand. You have one HDMI cable linking your TV and AVR? This is only to send video and sound out to your TV from the AVR you will not be able to send sound back over this same cable. You'll have to use the TVs audio out and connect it to an input of the AVR. The "HDMI out" on the AVR is just that Out and not In. For more questions I'd recommend checking out the RX-V3800 RX-V1800 thread over on AVSforum.com
Aug 10, 2008 | Yamaha RX-V3800 Receiver
Computers & Internet Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
