Question about Dishwashers
Rinse arms have been thoroughly cleaned ,replaced and spin very freely , but will not spin resulting in poor washing results, could it be pump ?
    Top Expert:
  • Dishwashers Master
  • 43,003 Answers
If said pump suppliesthe water to the spray arm of course it cold be . just like lawn sprinklers the more pressure the faster then spray goes round and round
Posted on Mar 29, 2015
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Top Loading Washing machine Stopped working mid-load
You may find a piece of clothing has jammed the lower spinner or the mechanism is worn and jammed up.
Mar 06, 2014 | Washing Machines
After a regular dishwashing cycle, our dishes and glasses are not getting clean. They are left with a white film. We have checked and all holes in the spray arms are open. We have tried a rinse agent,...
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if you need more assistance.
Feb 09, 2011 | KitchenAid KUDR24SE Built-in Dishwasher
Dishes are not cleaned on the top level, the bottom level is OK, seem like the spray arm is not revolving
top spray arm will be blocked with sediment/food deposits etc remove clean thoroughly with hot soap water and shake/tap it on side of sink to dislodge deposits if the outermost holes are blocked the arm will not turn and you will get poor wash results.
Aug 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes on top shelf, usually cups and glasses, not washing correctly. Have tried rinsing cl eanser to no avail
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results. Might also be worth checking the other 2 spray arms at the same time.
Jan 25, 2010 | Belling 24 in. IDW602 Built-in Dishwasher
Top Arm does not spin so glasses are not cleaned and detergent is not rinsed out of holder very well.
Make sure the water level is just at or below the heating element. Low water level will cause the pump to "run out of water" before all wash arms and connecting tubing are filled. A pulsing sound during the wash cycle will verify. Low water pressure or a bad water inlet valve are one cause. Water siphoning ou the drain line is another. Look under your sink and verify the drain line goes from the garbage disposal or sink tailpiece all the way up to the bottom side of the coutertop enroute to the dishwasher.
Apr 27, 2009 | Dishwashers
The arms do not spin and no water is going through them
Switch to a brand name powder detergent like Electrosol or Cascade. Never use ultracheap, generic DW detergent powder in any dishwasher. Run a load with dirty dishes and see the results are.
If cleaning results remain poor open the sump area by removing the lower spray arm and the filter assembly. Remove all debris in and around the sump area. Inspect the impeller down there to make sure it is not broken and that it spins freely. Clean the filter well in the sink. Reassemble. Also, check all spray arm holes for blockage.
Run a load of dishes and check cleaning results. If problems continue, you almost certainly have a failing wash motor and replacement is your next step.
Post here is you would like more assistance. Good Luck!
Apr 11, 2009 | Dishwashers
Dishes not clean, water spots
You might have really really hard water which would leave mineral deposits on your dishes,,, something could also be blocking the wash arm from rotating, or the water from shooting out of the wash arm which would result in very poor cleaning results
Mar 12, 2009 | Dishwashers
Ghw9150p wont spinr
you cleaned out the filter in the pump assambly??? and did you also check inside the throat of the impellar for possible obstruction?its possible that the pump is not pumping(although its on) and not removing water would result in no spin
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Owen Barnes
