Question about Fisher Paykel EcoSmart GWL15
My fisher and paykel GWL15 is dripping water from the top where the water comes from. What is the name of the part that needs to be replaced?
I'm going to attempt self repair, but I need to know which part needs to be replaced.
  • Fisher Master
  • 5,323 Answers
Hes talking bout the inlet water valve but what ur talking bout is the one where the water comes into tub thru the top plastic part ? think its called a water splash guard sometimes they get cracked or split and leak
Posted on Mar 30, 2015
    New Friend:
  • 26 Answers
Sounds much like the rubber diaphragm in the water inlet valve is split, which means that as long as the water tap is on you will get that drip drip drip of water into the machine.
You can still use the machine until you fix the problem, but the most obvious short term thing to do is to turn the water taps off when the machine is not in use.
To determine which machine inlet valve is leaking, turn on both taps, then turn off, first the HOT water tap as this is more often than not the least used. If the leaking persists, then it is the Cold Water Inlet Valve you need to replace on your machine.
While this repair can be done by a suitably skilled handyman, I always urge caution, because the average guy may just not have as well instilled "Safety Consciousness" as the professional technician who does this sort of thing all the time.
Remember, you are dealing with 240v A.C. which can deliver a LETHAL shock.......so unplug the power cord when doing any work as the least of safety steps to take. It only takes one forgetful mistake which could result in injury or worse!
Posted on Mar 29, 2015
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel GWL15 , i have leaking water dripping from the bottom of pump. do I change the pump or is there a seal that needs to be replaced.
Was the pump easy to turn and lock into place.
If it was easy to turn the seal is not seating tight on the bucket.
You need to tighten the four bolts on the gal plate to make pump seal sit tight against the bucket.
Aug 14, 2013 | Fisher Paykel EcoSmart GWL15
My five yr old Fisher Paykel EcoSmart washer is dripping water into the tub when it is off. Is this hard to fix on this machine?
Hi just read your posting.The problem with your machine is a faulty water valve.Now there is 2 ways you can rectify this .The first and cheapest is to turn off the taps to the machine after use or the 2nd is to replace the faulty valve or valves.Hope this helps and please reply on how you got on and if you would like to change the faulty valve or valves.Looking forward to your reply.
Jul 31, 2010 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washer dripping after wash is complete
replace your water inlet valve can order from Repairclinic.com
Mar 01, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher paykel gwl15 overfills and will not advance
Is it filling so it is flooding your floor? Could be that too many suds are in the pressure switch tube ( are you using "he" soap? ) or the pressure switch is not registering the water level. Note the lights illuminated when it beeps and call F/P.
Jul 03, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
Mar 21, 2009 | Fisher Paykel EcoSmart GWL15
Getting inside the Fisher-Paykel GWL15 washer
thats it , remove those 2 screws and the top will flip back, the new "clothes guard"( neck ring), will snap right into place, be sure to rehook the spring to hte left front susension rod!
Mar 25, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
671 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
