Question about GPS
How can I get 13.6 in to my tom tom all I can get are 13.14.no inbetween
8x + 10y=-14 -x+y=13
y=13-x, so 8x+130-10x=-14, so -2x+130=-14, so 2x=14+130 =144, so x=72 and y=13-72 =-59
Oct 23, 2014 | Toys
Let U = {9, 10, 11, 12, 13, 14, 15}, A = {9, 10, 11, 12}, B = {9, 10, 13, 14}, and C = {11, 13, 15}. List all the members of the given set. (Enter your answers as a comma-separated list.)
List all members of which given set? The members of U are {9, 10, 11, 12, 13, 14, 15}. The members of A are {9, 10, 11, 12}. The members of B are {.9, 10, 13, 14}. The members of C are {11, 13, 15}.
Jun 14, 2014 | Office Equipment & Supplies
Math mean median mode
The question is incomplete.
The mean, also called the average is defined as
mean= (sum of the data values)/(number of data elements)
Mode = the most frequent data value (the one that is most repeated)
To find the median:
  1. Order the data values in ascending order (sort them from the smallestr to the largest), and
  2. Locate the data value that is in the middle.
  3. If the number of data values id ODD (not a multiple of 2) there is only one middle element. That is the median.
  4. If the number of data elements is EVEN (multiple of 2), there is not one middle element but two.
  5. The median is the average of the two middle element values
    1. Median =( left of middle value +right of middle value)/2
    2. Imagine this median value to be inserted between the two middle elements
Example 1
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20)/9=?
Mode= most frequent value. Here it is 13 (repeated 3 times)
There are 9 values, an odd number. Middle element is the 5th ( 13.5)
Median=13.5
Example 2
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20, 25
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20 + 25)/10=?
There are 10 values, an even number. Middle element is not among the values. There are two middle elements (the 5th and the 6th) or
The value of the median is the average of the 5th and 6th elements or
Value of Median =(13.5+14)/2=?
Nov 21, 2013 | Computers & Internet
I want to know the total sq foot of a 16'x14' room the total of a 14'x5' and a total of a13'x13' room Or the total of all 3 together. Thanks
If you have a calculator just turn it on and typ[ what follows.
[X] means you press the multiplication key
[=] means you press the = key
[+] means you press the addition key (plus)
16 [x]14 [=] area of first room.in square feet
14[X]5[=] area of second room.in square feet
13[X] 13= area of third room in square feet
If you want to obtain the total area of all the rooms at one go
16 [x]14 [+] 14[X]5 [+]13[X]13 [=]
Aug 25, 2011 | Office Equipment & Supplies
2004 z71 180000 miles. drove from VA to TX. Headlights started dimming, battery not charging indicator came on. Battery charging level is not in the red but on the lower side (9-14-19) showing inbetween 9...
if battery and alternator are good. i would check the wire from alternator to battery, they sometimes have a fusable link in the wire, that burns out. also check fuse box there may be a fuse and it may be blown! at battery with car running should be at least, 14 to 14.2. at battery when car is off should be about 12.8 to 13 volts. have a good day !!
Nov 26, 2010 | 2004 Chevrolet Suburban
Battery dies. I have a Venox and I put a volt meter on the battery and with the headlight unplugged, it reads 14 volts. But, when I plug the headlight in the volt meter reads 13 volts and the battery...
to check if the charging system is charging you also need an amp meter hook that inbetween the battery lead on the pos + side of the battery and with the engine running turn on all lights if the amp meter reads - charge its not charging the batery up,,change the reg first,, thats the chepest part,,,the charge will only just be above what you need with all lights on eg 1.5 - 2 amps
Aug 14, 2010 | 2005 Kymco Venox 250
Computer won't boot - there's a flashing 1 and 3
Either the power supply has failed or the power cable is not getting power to the board (if the lights are amber). Check that the power cable from the power supply to the motherboard is fully seated. You may need to replace the power supply - you will need one that will fit your case and matches the various devices and plugs that you currently have. (20+4 pin for the motherboard gives the most flexibility, additional power for the CPU (4 pin or 8 pin), SATA if you have SATA devices, regular 4 pin peripherals for IDE hard drives and optical drives, 4 pin floppy, video card (if you have a PCIe card that needs a 6 pin plug), etc.)
I hope this helps.
Jul 13, 2010 | Dell Precision Workstation 490 - MT -...
Tom Tom One won't find satalites
sounds like a typical TOMTOM!
i would suspect that your battery is not getting charged properly before your trip The DC does not produce sufficient reserves to maintain a full chartge and so from time to time the signal will drop out and as ther battery depletes it gives wrong info and takes you on a journey to the land of the lost. Barc to Lisbon is a long Journey and unless you are charging inbetween stops at your hotel then your battery is very low. Charge it and it should work a lot better.
Jun 28, 2009 | Tomtom ONE GPS Receiver
Corupt tom tom
How to contact Support
icon_register.gif Need information on how to use this site? Or how you can contact us? Follow the link below or call
Mar 15, 2008 | Tomtom ONE GPS Receiver
GPS Logo
42 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
