Question about Miele DA289-4 Designer Wall Mount Hood - Stainless Steel
How do we remove the glass hood on our Miele DA289-4 to redo our backsplash? How is it removed? The instructions to install/dismantle is not found in the manual.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Refresh me pls. Is this the one with the curved glass? If so, there are two nuts on top. Make sure you do not lose the silicone washers. These are vital to go back in.
Posted on Apr 24, 2017
2 Suggested Answers
  • 177 Answers
SOURCE: Need the glass hood for a Miele DA289 Range hood
hi,
you can only purchase Miele spares from Miele or through a Miele service agent. have a look on the Miele website for your nearest Miele branch
Posted on May 14, 2010
MEW 7627A double ovens keep cutting out with a click and then turns itself back on again. The control panel has been replaced and it is still doing the same thing
Hello Sheryl;
My name is Peter. I am a retired field service appliance technician.
If your unit is new it should still be under warrantee for one year.
Who replaced the control board was it a service company? You should have a 90 day warrantee on the work, which did not work.
Anyway, you may have a bad; "Infinite Switch".
An infinite switch allows the user to set the heat from low to high and everywhere in between, hence the name "Infinite." This switch differs from a "Low-Medium-High" switch, which provides only three heat settings. The infinite switch uses a bimetal switch and physically moves through the process of heating and cooling, causing the main switch contacts to open and close and controlling the power applied to the heating elements.Typically, when an infinite switch malfunctions, the surface element will not heat, or it will remain on high in every position.
  1. Before repairs or testing can begin, you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!.
  2. Next, depending on your appliance type/model, access the infinite switch using one of the following methods:
    1. For most standard models, remove the back panel.
    2. On models with front-mounted controls, the panel is attached with screws on both ends. Remove the screws and tilt the control panel, being careful not to let the wires disengage from the components.
    3. For models with a removable backsplash, simply lift the backsplash, rest it on the cooktop and remove the screws to access the components.
    4. If you are working on an eye-level range or wall oven, remove the control panel by opening the door and removing the screws that secure it. The screws may be located under the front of the exhaust hood or below the control panel. If the control panel is hinged, tilt the control panel towards you.
    5. Some models will require that you remove the rear panel and front panel before work can begin.
    6. If the front control panel is glass, remove the screws securing the trim that holds the glass in place.
Test for continuity between the switch contacts:
  1. Remove all wires from the switch terminals. (Remember to label them!)
  2. Set the infinite switch on high and place your ohmmeter on the L2, H2, P and H1 terminals to check for continuity.
    1. If there is no continuity between L1 and H1 or between L2 and H2, the infinite switch is defective.
    2. If there is no continuity between P and H1, the indicator light circuit is defective.
  3. Remove the infinite switch by removing the screws or nuts that hold it in place and install a new infinite switch by following the disassembly instructions in reverse order. Be sure to follow the wiring diagram and install the wires to the correct terminals.
REMEMBER YOU ARE
Feb 16, 2015 | Ovens Ovens
How can I remove the glass on my 2450 printer to dleanthe bottom of it? Where can I find instructions?
Hi!
You may check the link below on instructions about dismantling Epson 245, I was trying to find a video for more detailed instructions however I can't seen to find one, I'll keep you posted once I've found a tutorial video:
http://home.comcast.net/~cschofie/Pics/EpsonScanner/DismantlingEpson2450.htm
Hope this helps even a bit.
Apr 18, 2011 | Epson Perfection 2450 Photo Flatbed...
Oven does not work and the elements are good no f codes and the probe was change?
Hello there:
An oven thermostat is a switch that opens and closes in response to the temperature it senses. It is typically found in the control panel, where a liquid-filled temperature-sensing bulb senses and maintains the internal oven temperature by cycling heat on and off.
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. Access the oven thermostat, which is located in different places depending on the make and model:
    1. On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.
    2. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components.
    3. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel.
    4. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you.
    5. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  3. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
    Adjusting the thermostat:
  4. Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
  5. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
  6. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
  7. To remove the thermostat:
    1. Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
    2. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
  8. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Jan 05, 2011 | Frigidaire Ovens
Miele wall hood instruction manual
installation sheet:
http://www.mieleusa.com/manuals_pdf/Residential/Hoods/DA408_DA409_Install_sheet.pdf
operating manual:
http://www.mieleusa.com/manuals_pdf/Residential/Hoods/DA408_409_us.pdf
Sep 25, 2010 | Miele DA409 Kitchen Hood
hi,
May 13, 2010 | Miele DA 289-4 Kitchen Hood
Miele Diamante dishwasher. Rattles when draining.
possibly a piece of broken glass or similar you will have to dismantle pump to remove on the other hand your pump could be worn out and needs replacing either way you will have to check out the pump or put up with the noise
Feb 06, 2010 | Miele 24 in. Novotronic G851SC Plus...
I need to change the light
Miele lights are factory specific with odd power ratings not available in the US. Call Miele Parts Support for a replacement bulb. It is a consumable item no warranty. They may charge up to 70.00 dollars for a halogen bulb so be ready!
Oct 11, 2009 | Miele DA220 Kitchen Hood
Removal of cooker hood to locate electric plug
Thank you for your letter, we had to dismantle the whole cooker hood to get to the electric plug.
Thank you.
Jan 18, 2009 | Kitchen Ranges
Miele DA289-4 Designer Wall Mount Hood - Stainless Steel Logo
191 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Steve
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
