The water just ncomes straight out of the dispenser drawer and wont go in to the drum
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 61 Answers
The hoses from your despiser draw seem to be blocked you need to disconnect them and blow them through remember to unplug the machine before removing any panels.
Posted on Mar 31, 2015
3 Suggested Answers
SOURCE: he2 leaking from detergent dispensor
We had the same problem, It was a pair of sock stuck behind the seal in the drum blocking the water inlet to the drum. Like others we managed to get our fingers between the metal of the drum and the rubber seal near the detergent dispensor to remove the sock.
Posted on Mar 01, 2008
  • 49 Answers
SOURCE: Water does not drain from dispenser into tub/drum fast enough
I have addressed this issue many times with my customers. Often I find the cap from the laundry soap has fallen in and it makes it way down inside and backs up the water. Lately I have also found folks using the new soap pods are having issues with putting them in the drawer. The soap pods go into the tub.
Posted on Dec 25, 2014
Zwf1421w fabric softener wont wash away drawer just fills with water and I ahve taken the drawer out and cleaned it and the jets.
I had the same problem, machine not taking fabric conditioner.
So removed top of machine 2 screws and with a bit of wiggling dispenser drawer whilst holding down the drum easily slipped out after undoing a few screws and a small rubber hose.
Once out just a matter of separating the dispenser draw via 10 small clips. A good soak and scrub and l blasted it through with a hose pipe jet. Reversal of above and now works a treat.
Tip take picks before you startSent from I pad
Apr 29, 2012 | Zanussi Washing Machines
When I put the bleach in the dispenser it flows immediately into the washer. Shouldn't it wait until it has water to mix with?
the drawer is connected directly to drum, so it will run straight in. bleach should not really be used in w/m, but if you have too, put it in the drawer just after starting machine then close drawer to wash it down. hope this helps
Jan 01, 2011 | Whirlpool Washing Machines
My wirpool duet sport is leaking alot of water out of the detergent compartment whats wrong? Please help
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The water runs up out of the soap dispenser and not in the drum
Try removing the dispenser drawer and with the door open pour some water into the dispenser housing and see if it runs into the drum, if it DOES run into the drum the you have a dispenser housing issue.if it DOES NOT run it to the drum their is a plastic pipe that runs from the dispenser housing to the rubber boot that lets the water into the basket,a few times I have seen these get cloged with a item of clothing preventing water from draining into the washer Good luck
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Kenmore frontloader pooring water from soap dispenser
Oct 16, 2009 | Kenmore 44102 Front Load Washer
Water doesn't drain in to the drum, it is over flowing out the soap slide out.Something is keeping it from flowing into the drum.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Mar 28, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
