Question about Baumatic Refrigerators
What oven door will fit my baumatic bc720ss
I need both top and bottom replacment doors do i need to buy baumatic doors or can i get another make of door ?
SOURCE: Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Posted on Jan 17, 2008
  • 409 Answers
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
barkencoa
  • 3463 Answers
SOURCE: Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
Posted on Feb 08, 2009
SOURCE: Door Removal
If you don't have the manual, go to Samsung's website and download the manual. It explains how to remove and adjust the doors and bottom drawer.
Posted on Jul 25, 2009
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
How to relpace door glass on beautmic oven, model 610SS
Ok open the oven dor at a 45 degree angle , there is a plastic sealing section at the top of the door witch has 4 small slots in it . place a coin into each of the slots , turning clockwise to unlock the sealing section from the door . lift the sealing section from the door and the glass is now free to be removed . . . . Hope this helped you . . ..
Jun 28, 2012 | Baumatic Ovens
How do i find out what model my baumatic built in oven is?
There should be a small plate or label on the oven, giving all the details you require.
It could be at the bottom, or inside the door opening, on the rear, on the top of the oven itself, it will be there somewhere, unless it has come off.
Hope this helps.
Dec 17, 2009 | Baumatic B205SS Stainless Steel Electric...
Hinge broken on baumatic double oven door can it be replaced
Hi.
Yes it can, no ptob, but you will need to replace the pair, otherwise it will not close properly.
POlerase rate my solution.,
Thanks.
Jul 16, 2009 | Baumatic Ovens
If you got to:
www.youtube.com
Thanks.
Feb 07, 2009 | Baumatic B720 Electric Double Oven
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Can Get Door Back On
Just managed to put the doors on. Do the bottom door first. There are 2 little spikes on the bottom of the door. You need to slot them into the holes in the frame. Then make sure that the little metal flaps on the top of the door fit UNDERNEATH the inner door frame. Screw together.
Same with the top door, additionally add the trim on top.
Thanks to solution #1 - I've literally been fuffing about since yesterday evening, I was about to call out the engineer! :)
Jul 19, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Refrigerators Logo
44 people viewed this question
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
