Question about LG Washing Machines
I have lg wf-f7061dn washing machine when start the machine it starts for 5 to10second and then stops and then the inlet water magnet coil starts even I have change the watersensor.
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Check if the air hole to the sensor is clogged, if you have replaced the sensor with the correct one and there is no sensor fault.
Posted on May 07, 2015
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 99 Answers
SOURCE: Water keep refilling
Hi my name is joyce
you have a water valve problem just as you suspected its not shutting off your water when its supposed to it is just continually letting water come in your machine, also if you are on a well system check the back of your machine where your lines come into your machine their is a wire mesh filter that protects trash from getting into this valve, but sometimes it gets through this, so just uncrew the pipes and check this. I had this problem, if you dont have a filtration system on your house I would stongly recomend one to prevent this from happening again. I have a well and this has been a problem for me.
let me know if I can help with anything else,
joyce
Posted on Feb 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: my lg fuzzy logic wf s6607tc water level indicator
my daughter and myself give the lid cover a very hard knock and suddenly the washing machine works again.
Posted on Jan 11, 2010
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
could b eather a pressour switch prob or inlet valve sticking open
Apr 29, 2015 | LG Washing Machines
When I Fill my washing machine (Top loader Lg Wf-T7015tp), it Makes a Funny Noise and die when I start the program.Is it the Capasitor or is it the v-belt tension?
If the noise is only when this function of filling, and if you are only using one of the two fill valves, may be due to the magnets of the inlet valves of the water, which are activated in filling and are disabled when you start the program. that noise is normal unless it is very strong and is the preamble to the damage of the two valves.
Nov 10, 2014 | LG Washing Machines
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
I have a LG WF-T753A washing machine. The hot water is not working, but has in the past - cold water is fine. When it goes to fill up with Hot only, a slight hum, and then it stops, but no water. Have...
Check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
May 04, 2011 | LG WFT1071TP Top Load Washer
Problem with my LG washing machine WF-S7012DN model - 7 yrs old. Since yesterday, the wash/m starts to wash takes a turn or two and them stops with alarms on and flashing, (first time problem with my...
there is a magnet controlled switch in the top cover lid and the probable cause the magnet is missing.
The best alternative is just keep a good magnet on the top of lid & slowly move the magnet horizontally.At one point the BEEP stops & machine starts to function.
Jun 03, 2010 | LG WFT1071TP Top Load Washer
WF-F7061DN NO WATER FLOW IN TO THE MACHINE, UPTO
Water inlet valves tend to fail from time to time. This the most likely source of your problem..........Nomess
Apr 18, 2010 | LG Washing Machines
Lg wf-s6607tc
Aug 16, 2009 | LG WFT1071TP Top Load Washer
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
