Question about Radio Communications
Rear tail lights on BMW 525i.
Left rear tail lights go out intermitantly. I can apply slight pressure on the connector and get them to come back on. This implys to me a short in the wiring. Local repair shop says whole tail light assembly and 5 point connector needs to be replaced at @ $400.00.
How can I tell if all this work really needs to be done?
    Brigadier General:
  • 6,966 Answers
Your post/description:
1. "...can apply slight pressure...connector...come back on...: indicates a loose connection or probably corroded terminals. The easy way is to spray it with electrical contact cleaner. The preferred method is to disconnect connector and with a thin sharp object scrape the pins (both male & female). An indicator of corrosion is dull greenish/grayish discoloration of the terminals. At times when the color is brown indicates probability of high current or loose connection. Same cleaning would and should rectify. On some instances, the female connector might be loose where the male will no longer contact tightly. Applying a slight squeeze with a pliers should tighten it up a bit making the joint firm and solid. Of course, safe practice should be exercised and verify the ign/acc is off before doing any electrical work. Please make sure that you don't remove your battery terminals since most current models of car radio units will go into protective/lock mode when battery is disengaged.
2. "...short in the wiring..." beg to disagree. If it were a short, a fuse will blow and it will not light up even intermittently.
Hope this be of some help/idea. Pls post back how things turned up or should you need further information.
Good luck and kind regards.
Posted on Nov 14, 2007
BMW rear left hand side tail light and flasher not working also drivers window not working
The electric window could either be the fuse,switch, or window regulator motor at fault..Sometimes the window motor electric plug can vibrate loose or become loose from door slamming..Also the switch can become loose as well or contamination if you are lucky..You will have to remove door panel to inspect these components..and fuse panel..The light could be a faulty bulb..Check and replace bulb..before involving the signal indicator switch lever...If bulb is at fault go ahead and change bulbs at both rear sides..Do not try to repair signal switch because of air bag..If you can hold down on the turn signal switch and it works the switch is at fault...
Feb 21, 2015 | 2008 BMW 525i Sport
How do i replace left rear brake light bulb
1) Open trunk
2) Remove small round plastic access panel with a flat tip screw driver by prying open
3) Remove flat tip screw holding tail light assembly
4) Remove tail light assembly by pulling outward, careful not to break plastic guide/nub
5) Disconnect wiring connectors
6) Remove plastic housing access plate on back of tail light assembly by twisting/turning tabs until they click and then lift access plate from tail light assembly
7) When viewing the the bulbs, the turn signal bulb is the bottom left bulb
8) Install in reverse order, ensuring tail light seal seats properly during installation
Oct 13, 2014 | 1999 Audi A4
Bmw 525 i 1990 left rear tail light comes on only sometime what is the problem.
Check the ground wire first, it's the brown wire and several of them join on a tab that is bolted somewhere in the trunk. Check under the bolt for corrosion. Clean and re-attach.
Sep 28, 2014 | 1990 BMW 525i
Tail light not working at all done connectors,fuse,
Hi, Anonymous tail light issues are relatively easy to diagnose and repair and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
F650CS Electrical Issues
BMW F650 GS replacing bulb for broken brake and tail light motorcycle
2001 2005 BMW F650CS Service Manual Moto Data Project
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Dec 20, 2013 | 2005 BMW F 650 CS Scarver
Brake lights work tail light does not work, have new bulb
Hi, Imotiv8u tail light issues are relatively easy to diagnose and repair and the usual suspects are:
For more information about your issue and free downloads that you need please visit the websites below. Good luck and have a nice day.1100GS Tail light not working but brake light does
Question about my tail lights
https://www.tradebit.com/filesharing.php/search/0/bmw+r1100gs BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
Jun 27, 2010 | 1998 BMW R 1100 GS
Where is the battery on a 2004 525i bmw
Passenger side rear quarter panel in the trunk (yeah, in the trunk, believe it or not). Look under the pass side tail light in the trunk you'll see the two screws holding down the cover.
Dec 06, 2009 | 2004 BMW 5 Series
When the lights are on, all rear bulb are fine. When you press on the breaks, the break lights are fine. When you press on the breaks when the lights are on the right rear goes completely dark.
Hi remove the tail light and remove the electrical connector then remove the top globe by twisting it anti clock wise then bend the contacts on the tail light up slightly and install the globe and tail light back
Nov 01, 2009 | 1999 Jeep Grand Cherokee
Can't get to battery on 94 525i. I believe it is under the back seat but cannot remove the seat.
I found the owners manual and it says take it back to BMW!
Most other posts I found on the net say it is under the passengers side rear seat. But I guess that depends on if you have a right hand or left hand drive.
http://www.onlinefreeebooks.net/automotive-machinery-power-equipment-ebooks/bmw/bmw-525i-530i-545i-525xi-530xi-owners-manual-pdf.html
Aug 29, 2009 | BMW 525 Cars & Trucks
Radio Communications Logo
136 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
