Question about LG DLE5001W Dryer
Drum turns..no heat
Duct condition test shows 4 bars-complete blockage. Removed duct-no blockage. looked in back of dryer vent - no blockage. performed test with duct disconnected- 4 bars complete blockage
  • LG Master
  • 5,323 Answers
I would check inside and see the blower itself it may have lint or debris obstructing it, see if u can turn it by hand another thing to check is for full 220 at the outlet and terminal cuz if u only get 110 u will be able to run motor but have no heat
Posted on Mar 30, 2015
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Tip
Save on drying time and energy consumption!
A dryer is designed to exhaust so many cfm's as it drys through a 4" diameter venting system. The more choked the vent the more heat is backed up into the dryer. This in turn causes the sensors in the dryer to go on and off stopping and starting the heater system in the dyer more frequently then designed. That causes the dryer to take a lot more time and electricity and or gas to dry a load of clothes. Some time 3 or 4 times longer.
Check the flexible dryer vent from the dryer to the wall regularly for kinks and or lint build up.
The major cause of a blocked dryer duct occurs when the water in the clothes is heated to a high temperature and turned into steam, which is then exhausted out the back of the dryer to the outside of the house. As the steam cools on its journey and gets closer to the outside of the house, it tends to get cooler and turns back into water droplets. This is going to be the point where the dried lint, as it escapes past the lint filter, sticks to the newly formed water drops and starts a gradual chocking down of the 4" diameter vent to 3",2",1" and finally stops all flow of air.
Remember, the dryer is designed to exhaust so many cfm's and the more choked the vent the more heat is backed up into the dryer.
It is important to keep the ducting as free from blockages possible. If you are experiencing long drying periods, then it is important to get the lint build up cleaned out.
If you cannot access the dryer ducting, because it is in the wall or ceiling, to look for any obstructions, then look in the yellow pages or contact the local appliance repair service company and get the name of a good duct cleaning company.
Remember to check your venting regularly. A minimum every other year. You will be amazed at how much time and money you will save by doing this simple dryer maintenance.
on Apr 09, 2010 | Dryers
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
The dryer is taking 2-3 full cycles to completely dry the clothes. I have already unplugged the dryer, checked the hose, completely cleaned it of any dirt that was clogged a little. Also used the vaccum...
if you have heat in the dryer you have a blockage somewhere in the dryer or the vent line,how long is the vent line?also try removing the vent line from the back of the dryer and run it to see if it dries,i had a guy tell me he cleaned the vent line,i stuck a leaf blower in the vent line and blew out a birds nest.also check the outside duct,if there's a cage or screen on it remove it and keep it off and then blow out the line. also the duct that the lint filter slides into should be removed and cleaned.send the model number so i can look up your machine,if it's gas you could have bad gas coils,they work fine until they heat up like 15 to 30 minutes then no heat until they cool down and then they will work for a few minutes and stop again,send model number off of the dryer,open the door and look around the opening,you should see a tag with the model and serial number.
Mar 26, 2011 | Dryers
Dryer heats and turns but doesn't completly dries clothes
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Feb 13, 2011 | Kenmore 600 6965 Electric Dryer
Doesn't heat up. No exhaust blockage. Drum turning normal.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Dec 30, 2010 | GE Dryers
Takes 4 or 5 cycles to dry clothes.
Most of the time this problem is attributed to a blocked or more precisely, a partially blocked dryer vent system. When a dryer vent is blocked it stops the air flow and the heat backs up into the dryer turning the heat sensors on and off prematurely taking longer for the clothes to dry. Over time this may cause the heat overload fuse to blow and you will have no heat at all.
First take a look at the dryers ducting between the dryer and the wall to make sure the vent duct (normally a flexible style) has not been crushed or kinked.
If the dryer duct to the wall is in good shape then in most cases there is a blockage some where between the wall where the ducting connects to the vent and where it exhausts outside.
The major cause of a blocked dryer duct occurs when the water in the clothes is heated to a high temperature and turned into steam, which is then exhausted out the back of the dryer to outside. As the steam cools on its journey and gets closer to the outside of the house, it tends to get cooler and turns back into water droplets. This is going to be the point where the dried lint, as it escapes past the lint filter, sticks to the newly formed water drops and starts a gradual chocking down of the 4" diameter vent to 3",2",1" and finally stops all flow of air.
If you cannot access the dryer ducting, because it is in the wall or ceiling, to look for the obstruction, then look in the yellow pages or contact the local appliance repair service company and get the name for a good duct cleaning company.
Apr 08, 2010 | Dryers
LG DRYER 5955 - No heat; 4 bars in test phase; NO blockage!
some dryers have what is called a thermo fuse if it overheats due to bad venting the thermofuse opens and need to be replace it whit about 1:lonk mounted on the back of the dryer cost aprox 6.00 thanks from gilles
Mar 15, 2009 | Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My LG dryer will not dry anymore. Lint is only on 1/4 of the lint screen when I pull it out. It takes about 3 hours for one load to dry
First check that the duct is clear of obstructions.
A quick way is to place a wet towel in the dryer, remove the duct from the wall and let the machine vent inside of the house. run it at high heat without the filter screen in.
While it is running check for good air flow by placing your hand near the dryer vent. Also note if there is any heat. also listen for the sounds of the drum turning.
If there is good flow and good heat then the filter screen of duct needs cleaning. Inserting the filter screen and running the test again will tell you which it is. If there is a noticeable difference between filter in and filter out then the filter needs cleaning.
If there is good flow and no heat then the dryer element needs to be checked and either a thermostat or element replaced.
If there is no flow then the blower needs to be replaced.
If there is no drum spinning but heat and flow then the belt needs to be replaced ( Extremely unlikely)
If all of these conditions check out then you will need to call a tech in to diagnose.
Jul 28, 2008 | LG Dryers
LG DLE5001W Dryer Logo
265 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
