Question about Conair TravelSmart Travel Alarm Clock TS114AC
Need manual to set clock - Conair TravelSmart Travel Alarm Clock TS114AC
Need to set clock on my Chichester gas cooker no Manuel
GOOGLE! GOOGLE! GOOGLE!
Chichester gas cooker manual
The first 2 pages on a Google search are nothing but manuals.
Aug 04, 2016 | Kitchen Ranges
I need to set my radio controlled clock manually. Model 8N2 V00. Anyone can help me pls? thx
The nature of this type of clock is that you neither can nor need to set it manually. Your only input is the time zone and it will look for the radio set signal from Colorado. That model does not get any hits on Google. Who makes it?
Apr 09, 2011 | La Crosse Radio Controlled Atomic Clock
I need a manual for a Vextra CD/Clock Radio VX715. I can not figure out how to set the clock radio alarm
The settings on this clock were difficult to figure out even with the manual. I made a lot of notes in the manual to help myself each time I had to reset the clock and CD Alarm. See Attached .pdf.
Nov 13, 2010 | Audio Players & Recorders
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
Clock is flashing continuously and unable to set it.
Found the manual for this product here:
http://www.voxxsupport.com/images/manuals/RP5430/media/RP5430_UMEN.pdf
Looks like this clock has internal batteries that need replacing every 2-3 yrs.(See "auto-clock set" under "clock".
Hope this helps.
Dec 16, 2009 | RCA RP5430 Clock Radio
Pioneer
You can find a manual for your deck at: http://akamaipix.crutchfield.com/Manuals/130/130DEHP390.PDF
Page 34 walks you thru how to set your clock. You can save this manual for future reference. Thanks
Nov 25, 2008 | Car Audio & Video
Need instructions
I found the manual for you at http://www.timexaudio.com/pdf/T300IB57134_31.pdf
You cand find the manuals for all Timex Clock/Radio conbinations at:
http://www.timexaudio.com/product_manuals.asp
Go Get 'Em
FixedThemAll.......
Sep 28, 2008 | Timex Auto-Set Dual Alarm Digital Clock...
Need owner's manual to set time
i can't set the time i need help
Apr 12, 2008 | RCA RP4803 Clock Radio
Conair TravelSmart Travel Alarm Clock TS114AC Logo
51 people viewed this question
Top Conair Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Conair Audio Player and Recorder Expert? Answer questions, earn points and help others
