Question about Toshiba Televison & Video
Toshiba 8873 av no audio and video but RF is ok
Cerfer39
  • 709 Answers
SOURCE: hook up all my components together
Hi knit, You need a 4 port A/V switch. Ebay has one: http://cgi.ebay.com/4-Port-AV-Audio-Video-S-VIDEO-Selector-Switcher-w-Cable_W0QQitemZ150168531361QQihZ005QQcategoryZ73390QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Oct 05, 2007
Benimur
  • 6966 Answers
SOURCE: I want to setup my
Based on your query "...which jack...put the green cable ...", I would suggest that you replace that green cable with a 3.5mm Stereo Phone Male to Twin RCA Male as shown below.
19ba6b8.jpg. The stereo phone would match the green INput ((Front) of the Logitech X-540 while the twin RCA (white & red) would match the RCA AUDIO OUTput of the LG 37LC2D.
Of course hooking it up this way would not fully utilize the 5.1 features of the X-540 (Rear and Sub/Center) but the TV sound will come out of the front speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 09, 2008
  • 5 Answers
SOURCE: cant connect to audio video inputs
try a factory reset you can do it through your menu
Posted on Dec 19, 2008
SOURCE: Audio OK, NO VIDEO...Toshiba 32hl67u
I just had a technician call Toshiba about this exact problem. The response from Toshiba was that this was a major issue they were having with that particular model...it is the main board which needs to be replaced...the cost? $260 for the part plus $130 labor plus some other fee...making purchasing a brand new TV at about the same cost. I had emailed Toshiba and their solution response was to unplug it and wait an hour. Shame on Toshiba for being aware of this issue and still selling them...at the very least, they should have sent purchasers a recall notification or offered to pay for part of the repair. I am dumping this Toshiba and going to the LG. So there is the solution. Get another TV
Posted on Jul 21, 2009
westytech
  • 120 Answers
SOURCE: Westinghouse model LTV-17v1sl When I move from
There are a few things that could be wrong. Before I start I have to let you know that if you are getting audio on while you are on TV mode than you switch to the av mode than most likely it is a settings issue. Number one thing you have to check is that all the cables are connected properly. You have to make sure that you are using the correct white and red connection on the back of the unit because you can accidently connect them in to the YPbPr connectors. Another thing to try is to check on the settings while you are on the av mode. Please make sure you have the internal audio on and not the external. If this does not work you can send me a quick email to westytech@wde.com and I will help you find a solution to your problem. Please rate my comment on this page.
Posted on Apr 12, 2010
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
Tip
What to do if your TV won't take your Video/Audio cables
see, your DVD/Video device, outputs Composite Video & and an Audio signal, subsequently you must have AV inputs on your set they are Red & White (Audio) & Yellow (Video) RCA Jacks. If you do not have these then you are a bit stumped. You may however get a RF Modulator, this takes the Composite Video & Audio signal, and converts it into a TV Signal that can be "Received" on a TV Channels.
I have included a link so you understand what I am talking about.
http://cgi.ebay.com/Radio-Shack-RF-Modulator-Model-15-1214-PLUS-AV-Cables_W0QQitemZ300395036829QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f0f0809d#ht_500wt_1156
on Feb 13, 2010 | Audio Players & Recorders
Audio not ok pic ok
Hi ,
Check problem is in AV mode only or both AV and RF
If both mode problem is there follow the bellow
Other wise problem May RCA cable (AV cable)
I f you are able to open TV check speaker using a Multimeter (Tv should be OFF) continuity mode,is it shows 2 ohms or below speaker is ok, problem may be audio section of your TV.
Thank you
Apr 22, 2014 | JVC AV-21meu 21" TV
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
On the Dynex? - RF Modulator AV Signal Converter, the RCA plugs on the back, are they input or output?
Input. The intent is to convert Composite Video, S-video and audio from newer devices to old TV's that only have RF (antenna) inputs.
May 03, 2011 | Dynex RF Modulator AV Signal Converter
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
We have no manual - need instructions on how to hook it to the TV.
Nintendo 64 Hookups
Quick Tip! If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
The Stereo Audio/Video Cable that is included with the Nintendo 64 will allow you to connect the Control Deck to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have Audio/Video inputs . Though your TV may not have them, almost all VCRs do.
If you DO have AV inputs, choose where you want to connect to:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
If you do NOT have AV inputs, you will need to use an RF Switch and RF Modulator for your hookup. The RF Switch and Modulator are sold separately. (Where to buy):
Connecting the RF Switch to a TV
Connecting the RF Switch to a VCR
Other Hookups
Feb 24, 2011 | Nintendo 64 Console
I have a Magnavox TV I connected the VHS to, I get picture,but, no sound. How do I get the audio working?
First, you should see "Track" button on the VHS or VHS Remote, press the track severally still sound comes on. But if sound does not come on, you can follow th
There are two connection method you can use to connect our VHS to TV. 1. is RF wire and 2. is RCA (Yellow & White/Red).
Using the RF, Check the back of your VHS, you will see "RF Out", connect the RF wire to that part and the other to "RF IN" of the TV. Then search your TV and there should be a display and sound.
Using the RCA, Check the back of the VHS, you will see Video OUT and AUDIO OUT, connect the RCA wire there and the other part to IN of the, then press AV on the TV remote.
Good luck.
Oct 06, 2010 | Toshiba W403 VHS VCR
DP50747
a dvd or vcr has connections called AV this means audio/video inputs and outputs
a tv has inputs some even outputs.
the out puts from a dvd should be connected to the input of your tv both audio and video
later set your tv at AV channel
note AV has no showers small spots on your screen, the one with showers is a RF
Sep 05, 2008 | Sanyo DS13204 TV
AV 500 "No input signal" on multiple attempts
Check to make sure all of the configuration on the AV 500 are as they should be. If they are you are looking at a defective unit (might be hardware based) if it is I would suggest that is you do not have a background in electronics to take the unit to a repair shop. If you do have experience you will need the following items: A schematic diagram of the AV 500 A Multimeter to measure the voltages at test points of the AV 500 An Oscilloscope to measure the signals and levels at test points of the AV 500 if you have these pieces of equipment then you will want to start your test at the dectector stage (this is where video and audio are separated from the IF which is derivied from the RF so if you have video and audio at this point you know the input RF-IF-detector stages are working. Now based on your troubleshooting you inputted signal at the video processor by using the the video inputs, so from this I am going to take a stab at saying the problem more then likely would be located in the stages at and after the video processor stage (since in this case no signal may mean no video signal as opposed to no RF signal).
Sep 06, 2007 | Archos AV 500 400-Hours Video Recorder
Televison & Video Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
