Question about Life Fitness Tr9500 Treadmill Tr-9500 Commercial Gym Equipment Heart Rate
When I start running the treadmill will suddenly stop and I get a communication timeout message.
I recently serviced it and got a new belt installed but this problem continues.
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: communication timeout
You need to press and hold Pause,press clear twice. Continue to hold pause until the display reads SERVICE MENU. Press any up arrow and select SYSTEM TEST. then press enter in the desired mode,then the display will scroll automatically though available options. You want the first option which is SYSTEM COMM TEST hit enter upon do so it will perform test to communicate with all module within the treadmill. If a module does not respond to the upper console the a error message will display.
Posted on Mar 15, 2010
AJIN G
  • 6694 Answers
SOURCE: client run on treadmill then
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Posted on Feb 25, 2011
The belt stop while running by itself and if I step off it starts again
That belt needs to be adjusted so it does not slip under load.
Sep 02, 2015 | Reebok 8050 ES Treadmill
New running belt tracks to thr left
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Feb 04, 2014 | Precor C962i Treadmill 220V
When i get on the treadmill the belt stops all of a sudden
Try to tension the tredmill's belt. For that you need an allen wench. Watch the following video to adjust the running belt. All the treadmills uses the same way to adjust the belt.
Oct 10, 2011 | Reebok Vista Treadmill - RBTL13305
THE BELT ON OUR MACHINE IS BROKEN CAN I BUY A REPLACEMENT AND HOW DO WE FIT THE NEW ONE ON ?
The treadbelt can be installed by removing the front roller, the drive belt, rear roller and screws in the siderail. You do not have to remove both sides, just lift the deck and slide new belt on. To save yourself some agravation, you may cut the old belt off.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly... 877-805-1030
Mar 15, 2010 | Reebok Rt1000 Treadmill Walking Belt
Communication timeout message on a display
Mar 15, 2010 | Life Fitness 9500HR Next Generation...
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
The belt stopped suddenly and now won't work anymore
I would check your speed sensor. I've never seen one of these just stop suddenly. But running for a min or so is one of the signs a speed sensor gives you.( especially if the treadmill want speed up while it running) Check this out and if it"s not the problem get as much info as poss to help diag.
Nov 16, 2009 | NRS Golds Gym Preview 1000 Treadmill
My Proform 650v treadmill stop when running after couple of miles
Most likely a bad drive belt. Take the cover off the motor area. If you see black dust near the left side of the motor, replace the drive belt.
Oct 29, 2009 | Proform CrossTrainer Treadmill
Life Fitness Tr9500 Treadmill Tr-9500 Commercial Gym Equipment Heart Rate Logo
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
