Question about Smeg Ovens
Smeg suk 61 mx8 oven is not working, just the cooling fan runs and all the digital lights , the timer are off.
  • Smeg Master
  • 5,323 Answers
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Posted on Apr 17, 2015
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
  • 146 Answers
SOURCE: smeg single fan oven
Before you change anything try the broiler circuit. If the broiler works then it could be an element if not then you could have a problem with the oven thermostat.
Posted on Dec 24, 2007
hongster
  • 6 Answers
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Smeg oven not working
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
Smeg oven fan and heat not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 28, 2013 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
SMEG OVEN BRAND NEW WON'T HEAT
Sep 08, 2012 | Smeg Ovens
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
78 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
