Question about SewShop.com Singer Model 413 Instruction Manual
How to replace vertical shaft gear singer model 413
Feed dogs are not advancing material
check the position of the forward / reverse lever or knob
this indicates that the selection is in the middle
check for a broken drive belt in the head of the machine not driving the bobbin shaft
Nov 08, 2015 | SewShop.com Singer Model 513 Instruction...
I need a free manual for a singer 4016 sewing machine
Try writing to Singer and asking for a manual for your model....or Google the Singer model and include 'manual'. I can direct you to Smith Corona; www.willrepairservice.com. for any part, manual or repair for an electric typewriter.
Nov 16, 2014 | SewShop.com Singer Model 4016 Instruction...
How do I replace the Feed Drive Geer (Singer Part #174488) on Model 6234?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | SewShop.com Singer Model 6235 Instruction...
Timing after installing new belt
There are about 3 MAIN delicate issues here, could be needle bar, top shaft or bottle shaft, to understand timing first knowing that needle hook is passing the cusp of the needle on its way up....
Feb 25, 2014 | SewShop.com Singer Model 758 Touch & Sew...
What year is my singer sewing machine? AH251729? how do I purchase parts for it, like the zig zag attachment?
The Singer vintage machine site indicates that the AH251729 was made in 1947 in Elizabeth, NJ. For details see http://www.singermachines.co.uk/faq/tell-sewing-machine-age-from-two-letter-serial-number/ .
Look on the front of your sewing machine and locate the model number of the machine. Go to http://www.singerco.com/support/replacement-parts-chart and locate your model number. (Use the drop down menu and locate the group. Press Go and then find the pdf with the correct model parts list.) You can look up the exact part number and order them from the Singer Service Center online.
Alternatively, you may be able to find them at any Singer Authorized retailer. Just look at your machine and determine the type of shank that connects foot to the machine. (High Shank and Slant are common Singer foot designs on older machines.) Get a zigzag foot for Singer machines with that design. (If they don't have that, you can probably get a current foot and an adapter. We got an overedge foot and the high slant foot adapter for my Singer sewing machine (purchased in 1969) in the 1980s.)
I hope this helps.
(Singer parts are generally available. I saw throat plates for some Featherweight machines this morning at a quilt show.)
Sep 04, 2011 | Singer Vacuums
The "hand" run by battery
You have to take it all apart and clean the gears and shaft with keroseen on a rag. Use steel wool to take the rust off the shafts and gears and see if the motor will spin without the gears attached to it. If it does not that has to be taken apart and cleaned. When putting it all together use a light grease or vasoline and put a little on the gears and shafts. Put a little on the motor shaft but make sure you do not get it on the comutator where the brushes ride on the motor.
Mar 11, 2011 | Vacuums
I have a Singer 478 sewing machine and need to replace the top gear on the verticle shaft. Is there a repair manual for doing this. There was not category expert on this so please direct to the correct...
This is an easy fix. a lot disassembly required, you will need to gain access through the belt side to the singer cover plate,four clips hold it on from the back side. Once that is off, two screw hold small access plate which is under the letters Sin, remove plate, rotate shaft to access screw through opening which holds Vertical Top Shaft Gear, Singer # 155819 in place. Remove bottom cover, locate belt pulleys (2), remove cam tensioner, with a hex wrench remove pulleys, this makes it easier to remove lower belt. with a long thin, blade screwdriver, loosen screw on gear (through small access cover), slide shaft downward Rand R gear, reverse process, done. Be sure you document removal, take pictures, mark references with marking pen.This makes reassembly easy. I just replaced mine, I am handy but not an expert, hope this helps you...
Jan 27, 2011 | Vacuums
SewShop.com Singer Model 413 Instruction Manual Logo
Top SewShop.com Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
