Question about Samsung Galaxy Cell Phones
I need the apn settings for CAN rogers wireless inc' mobile network.
Sim card
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,745 Answers
Contact Rogers; they'll send you auto settings script.
Posted on Mar 30, 2015
Life wireless apn settings for at&t kyocera duraforce e6560
The best place to get these settings is from your service provider. Call up on their customer care hotline and ask. They'll send an SMS containing the settings.
Jun 20, 2017 | AT&T Cell Phones
I got the phone from a friend, did a factory reset. then turned it off and plugged in my T-Mobile sim card then restarted it. it picked up my sim card and contacts but will not let me call, no signal.
It may not be compatible with you sim. If you have t mobile as your carrier then it won't work with tracfones. the IMEI is set to tracfones network and not on t-mobile's networks. You could have your friend call tracfone and see it they will unlock the phone. As long as your friend had complied with there terms of service they might unlock it for him. Then you should be able to use it on t-mobile's network. Also check your apn settings.
Oct 17, 2015 | Tracfone Wireless ZTE Valet
I can't make calls nor receive
Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap the Connections tab.
  4. Tap More networks.
  5. Tap Mobile networks.
  6. Tap Access Point Names.
  7. If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
    Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
  8. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US LTE
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not set> OR Internet+MMS
    • APN protocol: IPv4/IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
  9. Tap the Menu key.
  10. Tap Save.
  11. Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection To manually select the wireless network the device connects to, follow these steps:
  2. Tap Settings.
  6. Tap Network operators.
  7. Tap Search now.
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G To change the band between 2G and 4G, follow these steps:
  2. Tap Settings.
  6. Tap Network mode.
  7. Tap one of the following desired band settings:
    • GSM / WCDMA (auto connect)
    • GSM only (2G only setting)
    • WCDMA only
Turn on / off Airplane mode Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
  2. Tap Settings.
  5. To turn on, tap Airplane mode to select the check box. Tap OK.
  6. To turn off, tap Airplane mode to clear the check box. Tap OK.
Jul 06, 2014 | Cell Phones
How to make internet setting in samsung galaxy s duos s7562
Go to settings, select more under data usage
then select mobile network then select access point names and press menu. after that select new APN, type your network name at the name column and type internet at the APN column..u r done..
enjoy ur internet
Feb 05, 2013 | Samsung Galaxy S Duos S7562 White Dual SIM...
No 3G signal on htc desire hd
3G depends on various factors . The basic requirement being a 3g enabled sim card .
1) Go to settings > wireless and network settings>mobile network> access point names> you need the APN from your service provider . 2) Also set the network to WCDMA/ GSM Auto .
Aug 08, 2011 | HTC Desire HD Cell Phone
How to set a mms setting on android version 2.1 and cyanogenmod...
The android setting is given below:
Name: M1 MMS APN: miworld (all lowercase) Proxy: http://wap.miworld.com.sg Port: 8081 Username: 65 Password: user123 (lowercase) Server: http://mmsgw:8002 (no slash behind....) MMSC: http://mmsgw:8002 MMS Proxy: 172.16.14.10 MMS Port: 8080 MCC: 525 MNC: 03 Authentication Type: PAPAPN Type: mms (lowercase
This is cynanogenmod setting
APN: rogers-core-appl1.apn
Proxy:
Port:
Username:
Password:
Server:
MMSC:
MMS proxy:
MMS port:
MMC: 302 (might be different - is auto-set by your SIM card)
MNC: 720 (might be 72 - is auto0set by your SIM card)
APN type:
APN protocol: IPv4
Regards
Jul 09, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I want to confugure internet on My Samsung galaxy Apollo I5801 (OS-ANDRIOD). How to Set Internet on this phone I searched but didnt find the solution. Please help. I am using BSNL Net Connection
From the menu tab
Select Settings Select Wireless and Networks Select Mobile Networks Select Access Point Names
Here you can add a new APN as per you provider settings. You can also edit the existing APN values by selecting the APN.
Sep 14, 2010 | Samsung Cell Phones
Network Connection error
This is a tutorial on how to add APN settings to HTC phones for your network providers. Example phone used is a HTC Hero but process is same for all HTC models.
Android APN and Data Settings Change for HTC Phones
  1. Go to settings -> wireless controls
  2. Go to Mobile Networks -> Access Point Names
  3. Click Menu and select New APN
  4. All you need to add for most networks is just the APN setting which can be obtained from your simcards network provider
  5. Press Menu and Save
  6. You are ready and have configured data connection settings.
Enjoy your HTC phones unlocked for Voice and Data for any network. see video below
May 14, 2010 | HTC Reusable Screen Protector Hero /...
I have a t-mobile sim card, but my phone is htc touch pro. The phone works fine, the only problem is I can not send or recieve text messages. My question is does anyone have the MMS settings for the Unicel...
You need the T-Mobile settings if you are using a T-Mobile SIM. assuming you are in US as Unicel not over her in UK so the settings are:
T-Mobile GPRS settings (T-Mobile EDGE settings) T-Mobile GPRS/EDGE settings for terminals (e.g., phone handsets). Some items are possibly Nokia-specific. I have found the authentication type can be either Secure or Normal. These settings should be useful for T-MobileWeb users.
APN: wap.voicestream.com IP address: 216.155.165.050 Data bearer: GPRS Username: [none] Password: [none] Authentication type: Secure Connection security: Off
APN is the GPRS Access Point Name.
T-Mobile GPRS/EDGE modem settings T-Mobile GPRS/EDGE network settings when using a device as a GPRS "modem", that is, when "tethered" to another device. Examples include connection via Dial Up Networking (DUN) Bluetooth profile, or via Universal Serial Bus (USB). These settings should be useful for T-Mobile Internet users.
APN: internet2.voicestream.com Username: voicestream Password: [none] SMTP server: myemail.t-mobile.com
Oct 15, 2009 | HTC Touch P3450 Smartphone
Wap settings for motorizr z3
Regular rogers wap
(not using phone as modem)
uses navigate plans
http://www.shoprogers.com/store/wir...ng/overview.asp
apn: goam.com
username: wapuser1
password: wap
IP 208.200.067.150.
or
172.025.000.107
Rogers Media settings
(for MMS/PICmessaging)
http://www.shoprogers.com/store/wir...remessaging.asp
apn: media.com
username: media
password: mda01
mms.gprs.rogers.com
ip 172.025.00.107
Rogers internet.com settings
(to use phone as modem. Or is needed for HTML phones, or wap 2.0 phones at this current time.
requires access to a Data access plan
apn: internet.com
username: wapuser1
password: wap
ip: same as goam, 208.200.067.150
Dec 06, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Cell Phones Logo
55 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
