Question about Garden
Lower blades not turning - Garden
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
If the motor is running and the blades are not turning check the drive belt has not broken or slipped off the pulley wheel. The other possibility is the key which slots into the pulley and drive shaft may have sheared.
Posted on Mar 29, 2015
How do I adjust the blade on a Planer
In between the rear handle and blade there is a brass knob. You turn that knob clockwise to lift the blade and anti clockwise to lower the blade.
Feb 07, 2015 | Crafts & Hobbies
How do you remove the blade on my toledo chop saw
Unplug the saw first. Then raise the guard and lower the blade onto a piece of wood to keep the blade from turning. Using a proper wrench, turn the nut in the direction the blade spins when cutting and remove the nut and blade.
Sep 04, 2014 | Saws
Changing blade scroll saw
Loosen the knob at the rear of the top arm - turn it counterclockwise several turns. The blade should now be loose. Push the "blade end" of the top arm down slightly with one hand while you unhook the top of the blade. Lower the blade a little to unhook it from the bottom arm.
Replace the blade. Hook it onto the lower arm first - you can look underneath to see what you're doing. The blade's teeth should point DOWNWARD - it's easy to accidentally install it the wrong way, so check that now. Again push down slightly on the end of the upper arm, then hook the top of the blade into the upper arm's blade holder. It should how stay in place, but loosely.
Now return to that tensioning knob at the top rear. Tighten it slowly until the blade is BARELY tight, not loose. Tighten the knob 1/2-turn to one full turn tighter to tension the blade.
Jul 24, 2014 | Craftsman 16" Variable Speed Scroll Saw
I change the news blade for Juki MO2516N serger but it doesn't cut the fabric. Please advise me how to fix it. Thanks, Van
hi there,
which blade you change? upper or lower one?
for lower one just make the top surface for blade aqual with throat plat.
for upper lower turn handwheel to make blade at lowest position in that time the upper lower must be lower than lower blade by arround 2.5mm and keep in your main the two blade also must be very close no space between it.
best regards
ashraf abozid
aabozid@hotmail.com
CAIRO - EGYPT
Jun 14, 2011 | Juki MO6714 Mechanical Sewing Machine
My bottom propellers won't turn. What could be the trouble? Only flew this a few times.
Same happened to me. I've found out that the white gear at the end of the right motor, that conects to the wheel and makes the blades spin, has been worn out by the harder plastic of the wheel itslef. So now they are no more in contact and thus the lower blades wont sping. I temporarily solved it pulling the white gear a bit lower but it lasted only for a couple flights more :-(
Jan 06, 2011 | Shuttle 9094 Emax Remote Control...
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Ariens 34 zoom blade binds at mid-height blade
Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Loose lower blade lock
Hi is the lower blade lock warn & needs to be replaced? Had a similar issue with another brand. Good luck
Mar 16, 2009 | Saws
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
