Question about Whirlpool Duet GHW9150P Front Load Washer
While draining out soap water it sounds very loud, like accelerator applied vehicle
    Sergeant:
  • 419 Answers
It seems like defective bearing or pump ,check out pump first if it is not pump problem then it is bearing and you better off buy new top load washer as repair bearing very expensive,
Posted on Mar 29, 2015
    New Friend:
  • 37 Answers
You either have something in the pump or your spin bearing is going bad. If it accelerates and gets slowly louder it is probably the bearings.
LG wf t7015tp makes a rattling noise when spinning
if it's noisy in the spin like metal or a loud rapping sound the spider gear is bad and it would be cheaper to replace it than repair it,this is usually from using to much soap and overloading,you might have a bad smell in your washer and like a black ring on the rubber boot,that's from to much soap,you should only be putting in two tablespoons of he soap that's it,the metal that the spider gear is made of is soft metal,the soap coats it and eats at it like acid and that's why the washer might smell,the extra soap gets onto the drain hose,the pump everywhere water goes,also it gets stuck in your clothing,i had one guy he was going to a skin doctor it was from the extra soap,his wife was using a whole cup full of soap he is double the strength so that's like two cups,but this is what it sounds like your problem is,
Dec 29, 2017 | LG Washing Machines
1994 lincoln makes a loud metallic twisting and popping sound when accelerating
check water pump bearings Check power steering bearings. Check fan belt for condition and tension.
May 17, 2013 | 1994 Lincoln Town Car
There is a loud swooshing sound, we think from water that got in. Is there a plug to drain it somewhere?
I had a similar swooshing sound under the vehicle on a '90 4 runner. Turned out to be water trapped in the running boards. Removed rubber plugs, water drained out, swooshing was gone.
Jul 16, 2012 | 1994 Toyota Land Cruiser
Upper tray doesn't clean, lower tray is fine. Also, lot of soap sticks in the soap compartment after the cycle. Thanx.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 31, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
Loud Ticking sound
Sounds like ignition timing if it only happens when you accelerate
Jul 23, 2010 | 1992 Toyota Pickup
I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Nov 18, 2009 | Crosley Washing Machines
Water in chassis from rain. When I accelerate or decelerate I can hear water rushing back and forth on both the drivers side and passenger side after a heavy rain. I took the trim off just under the door...
Water could be in the sill sections. There are usually several drains in every door and box section but the sill drains tend to be small and easily blocked by factory applied sealer as much as mud and dirt.
Sometimes a drain has to be "modified" and sometimes a new temporary or permanent drain must be produced.
The water location might be pinpointed by jacking the vehicle in certain ways while stationary.
Nov 15, 2017 | 2000 Mazda MX-5 Miata
Dishwasher not spraying
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Good luck!
Sep 12, 2007 | Dishwashers
Whirlpool Duet GHW9150P Front Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal De
